887VA struck in Rommon mode
luqman.ahmad
My Router always boots in rommon mode even though I boot the image from usb and cleared the complete flash and coped the ios from usb but i am unable to boot from flash not even with command
boot flash: (ios file name)
when it starts
System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
C880 platform with 786432 Kbytes of main memory
Readonly ROMMON initialized
loadprog: bad file magic number:      0x0
boot: cannot load "flash:c880voice-universalk9-mz.153-3.M.bin"
boot: cannot load "flash:"
dir flash:
Directory of flash:
2      1855      -rw-     c880voice-universalk9-mz.153-3.M.bin
rommon 3 > set
PS1=rommon ! >
IP_ADDRESS=10.1.1.64
IP_SUBNET_MASK=255.255.255.0
DEFAULT_GATEWAY=10.1.1.1
TFTP_CHECKSUM=0
FE_PORT=3
WARM_REBOOT=FALSE
TFTP_SERVER=10.1.1.64
TFTP_FILE=c880voice-universalk9-mz.124-24.T2
CONFIG_FILE=flash:c880voice-universalk9-mz.153-3.M.bin
MONRC=BOOT=flash:c880voice-universalk9-mz.153-3.M.bin
RELOAD_TYPE=1
BSI=0
RANDOM_NUM=2054262114
LICENSE_BOOT_LEVEL=
RET_2_RTS=15:28:03 UTC Sat Feb 22 2014
RET_2_RCALTS=1393082884
if i issue the ccommand boot flash:
boot flash:c880voice-universalk9-mz.153-3.M.bin
rommon 5 > boot flash:
only way i can load the ios is by:
boot usbflash0:c880voice-universalk9-mz.153-3.M.bin
Please any body can help me here
thanks in advance
2 Accepted Solutions
Leo Laohoo
The IOS you are using is corrupt or incomplete.  Look at the file size.
Download the IOS again from the Cisco website and compare the MD5 hash value before transfering the IOS across to the router.
Did you re-download the IOS from the Cisco website?
Did you check the MD5 hash value of the BIN file before you uploaded the file to the router?
7 Replies 7
Leo Laohoo
I have formatted the flash and router booted as normal but after implementing the router and wireless ap settings I reboot the router the image is corrupt again. I did that three times but once router reboots it goes into rommon mode because the ios image is corrupt again. i have other files on flash but they do not seem to be getting corrupt its just the ios image only
please advise if you have any soltution to that
I bought this router off ebay for home use and it worked fine at first but i deleted a file from flash ( I cannot remember).  have copied the IOS from router on my USB flash and checked the MD5 when uploaded to it back to router which was same as on flash drive and router booted from flash after copying IOS but when i load the config save them to NVRAM and reload it again corrupts the ios and goes into rommon mode.
I tried looking for the ios for thsi particular model but i cannot found this router support for cisco website its exact model is SRST887VDSL2 with voice and wireless N ap and system PID C887VSRSTW-GNA-K9
i got the ios from cisco site and mached the MD5 hash but when i boot it loads the ios and gives error message wrong ios for the router:
boot usbflash0: c800-universalk9-mz.SPA.154-1.T1.bin
program load complete, entry point: 0x80020000, size: 0x46d40
program load complete, entry point: 0x80020000, size: 0x1fdeb40
Self decompressing the image : ########################################################################################################################################################################################################################################################################################################## [OK]
Wrong IOS image for the router
This is the reason why.
I think you've downloaded the wrong file:
Look below:
This is the filename you should be downloading.
