A cisco 2960S 100% cpu
hi
On a Cisco 2960S-48TS-L, After a Mac flapping the CPU went to 100 %
700sw10_emb#sh proc cpu sort
CPU utilization for five seconds: 99%/5%; one minute: 99%; five minutes: 99%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 155    37771767     3603617      10481 23.51% 23.68% 23.53%   0 Hulc LED Proces
s
 225     4213295      956535       4404 23.31% 23.01% 22.98%   0 HULC DAI Proces
s
 234     3486099     1061257       3284 20.21% 20.41% 20.48%   0 IP Host Track P
r
 182     3761068      742168       5067 18.51% 18.40% 18.46%   0 Auth Manager
 104      244786     3413567         71  1.80%  1.57%  1.51%   0 HLFM address le
here is the log
Mar 13 17:43:38.076: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthe
rnet1/0/29, changed state to up
Mar 14 08:05:25.076: %SW_MATM-4-MACFLAP_NOTIF: Host 000b.6b22.7b72 in vlan 1 is
flapping between port Gi1/0/48 and port Gi1/0/51
Mar 14 08:07:52.602: %SW_MATM-4-MACFLAP_NOTIF: Host 000b.6b22.7b72 in vlan 1 is
Mar 14 08:09:16.681: %SW_MATM-4-MACFLAP_NOTIF: Host 000b.6b22.7b72 in vlan 1 is
.Mar 14 08:38:10.808: %SW_MATM-4-MACFLAP_NOTIF: Host 000b.6b22.79de in vlan 1 is
The only solution is restart the switch
regards
look at the processmax is
look at the process
max is utlizaied by LED process.
can you tell us from when did you notice the spike in CPU.
I saw it just after the last
I saw it just after the last mac flapping. telnet and snmp connections doen't work.
But everything is ok on the second VLAN
regards
Hall of Fame Super Gold
I am not sure what IOS
I am not sure what IOS version you are using but here's my recommendation:
1.  If you are running 12.2 then use 12.2(55)SE8; or
2.  If you are running 15.X then use 15.0(2)SE4.
Don't even bother using the others.
66
