A problem with cat3750-12s
So, an error message thet it displays in console:
00:43:27: %SYS-2-CHUNKINVALIDHDR: Invalid chunk header type 31744 for chunk 0, data 2C032000
-Process= "HULC multifs process", ipl= 0, pid= 38
-Traceback= BA03E0 1038F50 579598 57A6E8 57B84C 511378 5116F0 90CA44 90300C
--------------------Sh ver:
Cisco IOS Software, C3750 Software (C3750-IPSERVICES-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 08:46 by yenanh
Image text-base: 0x00003000, data-base: 0x010CE290
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEE3, RELEASE SOFTWARE (fc1)
Switch uptime is 43 minutes
System image file is "flash:c3750-ipservices-mz.122-25.SEE2/c3750-ipservices-mz.122-25.SEE2.bin"
cisco WS-C3750G-12S (PowerPC405) processor (revision N0) with 118784K/12280K bytes of memory.
Processor board ID FCZ1038X0FZ
Last reset from power-on
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:19:55:A5:75:80
Motherboard assembly number : 73-9678-07
Power supply part number : 341-0048-03
Motherboard serial number : CAT103655BN
Power supply serial number : DTH102345Y4
Model revision number : N0
Motherboard revision number : A0
Model number : WS-C3750G-12S-E
System serial number : FCZ1038X0FZ
Top Assembly Part Number : 800-26634-03
Top Assembly Revision Number : C0
Version ID : V05
CLEI Code Number : CNM81W0GRA
Hardware Board Revision Number : 0x06
Configuration register is 0xF
!!! WARNING: The switch is not usable !!!
-------------There are interesting message when it loading:
Waiting for Stack Master Election (around 30 seconds)...
POST: PortASIC CAM Subsystem Tests : Begin
TCAM (asic:1) walking-one test failed
Write: 80_00000000_00000000-00_00000001_00000000
Read: CA_E362DC2C_785B4505-23_D106232D_9475B2BE
POST: POST Failed
POST: PortASIC CAM Subsystem Tests : End, Status Failed
POST: CAM test failed
POST Failed: disabling stack links and shutting down SDP
driver class subsystem initialization failed
Version ID : V05
So, if have any experiense in resolving this problems, please help me. I don't know what can I do with this problem. But I must resolve it and this Catalyst must be operable in 1-2 days.
Thanks in forward!!!
Re: A problem with cat3750-12s
sorry, i didn't have time to read your whole post, but the moment i saw traceback i thought to myself, "he needs to call TAC". I had some traceback errors not too long ago on a switch participating in a 3750-48g switch stack and called Cisco and they said traceback errors usually need to get decoded by them. I think they'll ask you for a copy of your logs and a "sh tech". With my problem, they ended up replacing the switch with a brand new one. Hope this helps.
Hi Anton,
There is a hardware failure on this switch, you need to get a replacement for this switch. Check this:
POST: POST Failed
Its failing "power on self test ".This is a hardware failuire. Go ahead and get a new replaced switch.
HTH,Please rate if it does.
-amit singh
Hi, how have you managed this issue? I am experiencing the same problem. Thanks, Douglas.
762
