aaa authentication behaviour
mahesh18
Level 6
Level 6
Hi All,
I am trying these two command to be on switch at same time but switch only takes one command on its running config
3550SMIA#sh run | inc aaa
aaa new-model
aaa authentication login MP group tacacs+ enable                 1
aaa authorization exec default local
aaa authorization exec MP none
aaa session-id common
3550SMIA#config t
Enter configuration commands, one per line.  End with CNTL/Z.
3550SMIA(config)#aaa authentication login MP none                2
3550SMIA(config)#end
aaa new-model
3550SMIA#
As you can see the command 1 is gone now.
Is this the default behaviour with aaa authentication command ?
MAhesh
Marvin Rhoads
If you want both login authentication methods (TACACS+ with fallback to none) then they need to be concatenated on one line. e.g.:
     aaa authentication login MP group tacacs+ enable none
See the example in the command reference here.
Marvin Rhoads
Many thanks Marvin.
