05-09-2014 11:24 AM - edited 03-07-2019 07:24 PM
I'm looking to understand AAA commands better and different ways to setup it up. I've looked at the manuals but get lost mostly because it's boring to read. Is there a resource or a site that breaks this down in a better format that other folks have found helpful?
05-09-2014 11:33 AM
whats exactly you are trying to do with AAA ? you want to set up SSH access via aaa or something ? or you want to set up AAA for vpn authentication ? what device are you working on , is it a ASA or router or switch as AAA config will have difference between them?
05-09-2014 11:44 AM
I'm not trying to do anything particular just yet, except learn a little more about them. I apologize for being vague. For example when I look at some of our configs I'm trying to understand what exactly does a command do. Take the first one for ex. I researched it some and the manual just confused me more than helped me on what this really does. I understand setting up SSH and doing simple things as I just passed the CCENT but studying for that didn't get down in the weeds on a lot of topics I feel I should know. Is this a method list? I'm not sure as I just read about that term today. I'm more of a visual learner so seeing some type of flow chart would make more sense like if a switch had "aaa authentication password-prompt PASSCODE---->" this command X..Y..and Z happens because of this. That type of thing.
aaa authentication password-prompt PASSCODE---->………...
aaa authentication login default group radius local
aaa authentication dot1x default group radius
aaa authorization exec default group radius local
aaa authorization network default group radius
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
05-09-2014 11:55 AM
The command "aaa authentication password-promt PASSCODE" will change the prompt from default of password: to "PASSCODE" , for ex if you put in a command :
"aaa authentication password-promt PASSWORD HERE" will change the password prompt for the user to :
PASSWORD HERE : XXXX
Method List : In the command "aaa authentication login default group radius local" , the string "default" is the method list, you can use the command :
"aaa authentication login YOURNAME group radius local" and lets say we attach it with SSH , than it would be
line vty 0 4
login authentication YOURNAME // YOURNAME is the method list here.
For easy explanation just look for command explanation in cisco docs
http://www.cisco.com/c/en/us/td/docs/ios/12_2/security/command/reference/fsecur_r/srfathen.html#wp1018042
Manish
