aaa new-model
Howdy Experts!
i have an ACS 3.2 RUNNING ON THE Win2003 Server(10.10.10.1);i need to configure My access Switches to be Aunthenticated by This Acs Beofor the loging to the Switchs.
1)what could be the Proper Configuration on each access switch?
2)in wich we use Tacacs-server 10.10.10.1 .
& in wich case we use Radius-server 10.10.10.1
3)also what could be the configuration on the Acs to accomplish the Setup.
10xs for ur help!
Re: aaa new-model
Hi Sayeed
U need to configure the appropriate clients in the ACS.Then u need to configure the swithces or routers to forward any access request to the aaa server i.e u r tacacs server.
Hope the below link will help u .
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7a7.html
Mahmood
Re: aaa new-model
Ok;So the Config on all access Switchs it will be as the following:
aaa new-model
aaa authentication group tacacs+ local
tacacs-server host 10.10.10.1
tacacs-server key cisco.
is it a proprer config?
2) in regards to ht Acs Config,what shoud i configure?
10xs
Re: aaa new-model
HI
It should be like this
aaa new-model
aaa authentication login default group tacacs+ enable local
aaa authentication enable default group tacacs+ enable
tacacs-server key {password}
Mahmood
Re: aaa new-model
Hi Mahmoud 10xs for ur reply!what about the configuration at Acs Side?what about if we use Radius?in which case we use Radius Instead of Tacacs+..
10xs for ur time
Re: aaa new-model
In ACS when u log in u will find a option called network configuration click on it u will get the options to add the clients i.e u r network deivces.if u r using radius then replace the tacacs+ with radius option.
Mahmood
Re: aaa new-model
Hi Mahmoud;10xs for ur reply!
Mahmoud in wich Branch r u?in Jedah or Khobar?
plz can u mail me to the Following Contact:
aldoctors@hotmail.com
10xs
Re: aaa new-model
Ali u can contact me on mahmood_mkl@yahoo.com
I m in jubail
Mahmood
155
