About RSPAN question
I want to capture packets between two servers belonged to different VLAN. Two servers are connected to different access switch Cat3750, and those access switches are connected directly Cat6500. I think I have to run RSPAN between three switches.
Please check the following configuration:
Switch 3750A:
vlan 22
remote-span
monitor session 1 source interface gigabitethernet1/0/2(connect to ServerA)
monitor session 1 destination remote vlan 22
Switch 3750B:
vlan 22
remote-span
monitor session 1 source interface gigabitethernet2/0/2(connect to ServerB)
Switch Cat6500
vlan 22
remote-span
monitor session 1 source remote vlan 22
monitor session 1 destination interface Gi3/15 (connect to monitoring server)
My questions is:
a. How to guarantee we only receive the traffics between two servers on the monitoring server?
b. Do I have to remove VLAN 22 from the trunk interface connected to Cat6500?
Please advice! Thanks a lot
Re: About RSPAN question
To answer your first question. You will not be able to guarantee you only receive traffic between the two servers. With the configuration you're displaying, you are mirroring all traffic going to and from the specified interfaces to your remote vlan. You will need a tool like wireshark to filter the source and destination IPs to only view traffic between the two servers exclusivel.
I don't fully understand your second question.
To answer your first question. You will not be able to guarantee you only receive traffic between the two servers. With the configuration you're displaying, you are mirroring all traffic going to and from the specified interfaces to your remote vlan. You will need a tool like wireshark to filter the source and destination IPs to only view traffic between the two servers exclusively.
Thanks for your suggestion.
I already used VACL to complete packet capture.
123
