Access denied
cisconoval
Hi there,
there is two servers one is on VLAN10 and another on VLAN20.
User needs the access between these server on port 80. I tried to telnet on port 80 from to these servers from its respective VLAN which was successfull. But from the server its blocking. I have checked the ACLs there is no such thing to block. the ACL is like this
permit tcp any any reflect tcptraffic.
Can some shen a light on this at the earliest
Thanks in Adv
10 Replies 10
cisconoval
can some one help me please...its very urgent..
If I have missed out any information please let me know
On which side of the switch is this access-list applied?
Narayan
placed on VLAN10(source) as out
Can you try to add the access-list on the other vlan too and check
Narayan
I hope its not required because from Vlan10 to server I can telnet but from server on VLan10 only its not happening...!!!
Why it is happening like this what would be the root cause please...
Is any more suggesstion please.
Did ping and tracert from Server A(VLAN10) to Server B (VLAN20) which was successfull..
Take out the ACL and what happens?
I hope the secinario is confused for you...
Just to recall..
I can telnet from switch (Vlan interface to server) but not from particular server..
more over the ACL is
Ok then... post switch config and servers ip configuration and mask/gateway information
Can you please guide me the troubleshooting steps..as its policy violation I cant post the config details more over its Distribution layer switch....so masking the sensitive info is bit tough...
please
