07-01-2007 02:32 AM - edited 03-05-2019 05:03 PM
Here is the senario...
there are 2 access layer switch 1&2 they are connected using access link,on switch1 i have all ports in vlan2 and on switch2 i have all the ports in vlan 10.
will i be able to ping from a system connected to switch1 to system on switch2 the system are in same subnet.
07-01-2007 02:46 AM
Although this is a weired setup, but it should work, as the frames are sent untagged on access ports.
HTH,
Mohammed Mahmoud.
07-02-2007 12:32 AM
thanks for the reply..
One more doubt with the access port on both side show up or flap,since they belong to different vlan
07-02-2007 12:51 AM
As i told you before although this is a weired setup as it makes no sense to connect 2 switches via access ports, they should be connected via trunk ports (in order to be able to handle all the VLANs between the 2 switches), but it should work as the frames are sent untagged on access ports and this shouldn't have any impact on the ports.
HTH,
Mohammed Mahmoud.
