Webcast-Catalyst9k
ACE-VIP issue
Hi All ,
ACE virtual ip is not reachable from member server .
need help here to understand if this is possible to ping from inside lan to a vip .
from outside the vip is reachable .
Thanks 4 reply
ACE-VIP issue
Enbaling source-nat should solve your problem.
Ajay
ACE-VIP issue
Hi Ajay ,
Can you elobrate I m not able to get your point here .
from the document -
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/rtg_brdg/guide/iproute.html#wp1265744
When you use traceroute to a VIP address configured on the ACE, the ACE does not intercept traceroute packets sent to the configured VIP address. The ACE attempts to match the packet to the load-balance policies. If a protocol match occurs, the ACE sends the packet to the real server that responds to the traceroute accordingly. Will this be the same case when you do ICMP ping to VIP from real server .
will this be the same case when we use ping from realserver to VIP .
Thanks 4 reply -
ACE-VIP issue
Hi Ajay ,
from the document -
Thanks 4 reply -
ACE-VIP issue
Hi Ajay ,
from the document -
Thanks 4 reply -
419
