01-01-2014 01:13 PM - edited 03-10-2019 12:25 PM
I had the first two lines in the access list and all was well, I then added the 3rd. From what I need to put the 3rd entry (deny host 10.1.30.51) after the second entry and before the permit any. Even though I created sequence numbers in order of the 3 entries (10,20,30) the sequence numbers didnt put them in order and they dont even show up in the show run. What went wrong? How is it possible to edit an acl without sequence numbers also?
Cause if I had:
10 deny x.x.x.x
20 deny x.x.x.x
30 permit any
Then I could add say 15 deny x.x.x.x, but now I cant and I dont even know what happened to the sequence numbers when I created them.
Thanks.
Standard IP access list 1
deny host 10.1.30.50 (4 match(es))
permit any (8 match(es))
Router#
01-01-2014 01:40 PM
Then sequence-numbers are only visible in a "show access-list" and not in a show run. If you want to add a line at a specific position, just take an unused sequence-number and add the new line. It will be added at the right place:
c1841#sh access-lists
Extended IP access list TEST
10 permit icmp any any (5 matches)
20 permit udp any any
30 permit esp any any
c1841(config)#ip access-list ext TEST
c1841(config-ext-nacl)#15 permit tcp any any
c1841(config-ext-nacl)#do sh ip access-list TEST
You can also renumber your ACLs if you want to.
c1841(config)#ip access-list resequence TEST 50 20
c1841(config)#
c1841(config)#do sh ip access-list TEST
50 permit icmp any any
70 permit tcp any any
90 permit udp any any
110 permit esp any any
c1841(config)#
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
01-01-2014 04:30 PM
As you can see below, I create a new statement in the acl, add a sequence #45, then do a show ip access-lists and it shows none of the sequence numbers.
Router(config)#access-list 1
% Incomplete command.
Router(config)#ip acc
Router(config)#ip access-list s
Router(config)#ip access-list standard 1
Router(config-std-nacl)#45 deny host 10.1.20.50
Router#show ip access-lists 1
deny host 10.1.40.50
01-01-2014 07:53 PM
Packet tracer doesnt use the sequence numbers.
01-02-2014 03:09 PM
Sequence numbers are only relevant in extended access lists. In standard access lists they are ignored.
01-02-2014 03:42 PM
Collin,
I do not believe this is right. Why do you believe that sequence numbers in standard ACLs are irrelevant?
Best regards,
Peter
01-03-2014 01:17 AM
Hi Peter,
it seems that sequence numbers in standard ACLs are irrelevant when the standard ACL is named with a number (1-99) but are relevant when it's named with a word?
(At least it looks so in my lab.)
See http://www.cisco.com/en/US/docs/ios/12_2s/feature/guide/fsaclseq.html#wp1040665
Best regards,
Milan
01-03-2014 02:05 AM
Hi Milan,
I just verified with a 12.4 image and sequence numbers appeared in sow access-list whether the acl was created as a numbered or named acl.
Regards.
Alain
01-03-2014 02:23 AM
Hi Milan,
Sequence numbers are indeed not supported if you define a numbered access list. With both standard and extended numbered ACLs, however, it is possible to do a trick: if you refer to them as named ACLs (use their number as their name), you actually are able to use the sequence numbers.
For example:
R1(config)# do show run | i access-list
access-list 1 deny 192.0.2.1
access-list 1 permit any
access-list 100 deny ip host 192.0.2.1 any
access-list 100 permit ip any any
R1(config)# do show ip access-l
10 deny 192.0.2.1
20 permit any
Extended IP access list 100
10 deny ip host 192.0.2.1 any
20 permit ip any any
R1(config)# ip access-list standard 1
R1(config-std-nacl)# 15 deny 192.0.2.15
R1(config-std-nacl)# exit
R1(config)# do show access-list
10 deny 192.0.2.1
15 deny 192.0.2.15
20 permit any
R1(config)# ip access-list extended 100
R1(config-ext-nacl)# 15 deny ip host 192.0.2.15 any
R1(config-ext-nacl)# exit
10 deny 192.0.2.1
15 deny 192.0.2.15
20 permit any
The router is even smart enough to disallow to refer to a named ACL whose name is a number of the opposite type than stated on the command line:
R1(config)# ip access-list standard 101
% Invalid access list name.
R1(config)# ip access-list extended 2
What Collin may have in mind, though, is that host entries in standard ACLs are reorganized to a different order than entered:
R1(config)# ip access-list standard Test
R1(config-std-nacl)# permit 10.0.0.1
R1(config-std-nacl)# deny 10.0.0.2
R1(config-std-nacl)# permit 10.0.0.3
R1(config-std-nacl)# deny 10.0.0.4
R1(config-std-nacl)# permit 10.0.0.5
R1(config-std-nacl)# deny 10.0.0.6
R1(config-std-nacl)# permit 10.0.0.7
R1(config-std-nacl)# deny 10.0.0.8
R1(config-std-nacl)# permit any
R1(config-std-nacl)#exit
R1(config)# do show access-list Test
Standard IP access list Test
80 deny 10.0.0.8
20 deny 10.0.0.2
30 permit 10.0.0.3
10 permit 10.0.0.1
60 deny 10.0.0.6
70 permit 10.0.0.7
40 deny 10.0.0.4
50 permit 10.0.0.5
90 permit any
R1(config)# do show run | section Test
deny 10.0.0.8
deny 10.0.0.2
permit 10.0.0.3
permit 10.0.0.1
deny 10.0.0.6
permit 10.0.0.7
deny 10.0.0.4
permit 10.0.0.5
permit any
This reordering happens only with standard ACLs and is a result of indexing the host entries in the ACL into a hash table (the hash function being XOR of individual octets of the IP address in the host entry) for faster access. When printing out the ACL, first the host items are printed out in the order they are stored in the hashing table, and only then the remaining entries that use wildcards. Wildcard entries are not reordered.
The funny thing is that the ACL is actually even stored in the configuration in the reordered form, and thus evaluated in a reordered form, which can be confusing. However, you may have noticed that the router will prohibit you from entering a host ACL after entering a wildcard ACL that also matches the IP address in a wildcard entry:
R1(config)# ip access-list standard Test2
R1(config-std-nacl)# permit 10.0.1.0 0.0.0.255
R1(config-std-nacl)# deny 10.0.1.1
% Access rule can't be configured at higher sequence num as it is part of the existing rule at sequence num 10
Why is this? Obviously, a host entry can either select the same action for a packet that would be taken by a more general wildcard entry (in which case it is not necessary for the host entry to be entered at all), or it can override the action that would be chosen by a more general wildcard entry. In this second case, it is necessary for this host entry to be placed in the ACL first, otherwise it would never be reached. Ordering of host entries themselves can be arbitrary, as they do not influence each other. This leads us to a general logic in standard ACLs - it is required to put all host entries first, and wildcard entries last. Now it is completely logical to visit all host entries first (indexed by a hash for rapid access), and then visit the wildcard entries.
Quite a long post... sorry for that. Hopefully, we've resolved some of the doubts.
Best regards,
Peter
01-03-2014 05:02 AM
I have never found that you could not change sequence numbers whether it was standard or extended , numbered or named . As Peter said you just make all access lists so called named ACL's and just substitute the number for the name and you can modify anything. I believe this works even if you made the access list the old way , " access-list 5
ip access-list standard 5, enter then add or delete your entry.
I think you had some restrictions way back in like 12.2T code when they brought these features online.
01-03-2014 06:12 AM
Hi Peter,
you are correct - as usually.
I just missed the effect was due to the host entries in my lab ACL.
Only one comment:
I don't agree with Cisco logic all host entries shoud go to the beginning of any standard ACL.
Let's consider an ACL permitting access from private IP addresses and one public address:
c2811-R1#sh access-l 50
Standard IP access list 50
30 permit 77.65.77.1
10 permit 10.0.0.0, wildcard bits 0.0.0.255
20 permit 192.168.0.0, wildcard bits 0.0.255.255
Let's say the public address is used once a year.
Does it really make a sense to check each packet against the public host entry first?
Best regards,
Milan
01-03-2014 01:18 PM
Here I create a standard access list with a name called "ACL1":
Router(config)#ip access-list standard ?
<1-99> Standard IP access-list number
WORD Access-list name
Router(config)#ip access-list ?
extended Extended Access List
standard Standard Access List
Router(config)#ip access-list standard ACL1
Here is the ACL1 with two entries:
I created the sequence numbers as well.
Router(config-std-nacl)#do show ip access-list
Standard IP access list ACL1
10 deny host 10.1.30.50
20 permit any
Trying to apply the name "ACL1" to an interface returns a incomplete command
This I cant understand since that is the name I gave it, no?
What am I supposed to type here?
Router(config-if)#ip access-group ?
<1-199> IP access list (standard or extended)
Router(config-if)#ip access-group ACL1
Show ip access list comes with the sequence numbers.
Only if created with a word though, created with numbers it wont show the sequence
20 permit any
I think this is confusing for those studying for exams when I heard you cannot use the ? or tab when typing a command during the exam. How can you do this on the exam if it doesnt even work correctly in real life?
01-03-2014 01:26 PM
It gave you an incomplete command because you didn't specify in or out on the interface . If you create a numbered ACL if you do a show ip access-list 5 for instance the sequence numbers don't show ?
01-03-2014 01:34 PM
Thanks Glen that worked and it does show with the sequence numbers with a show ip-access-list, although I think sometimes Packet Tracer is acting up.
01-03-2014 04:52 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Packet tracer is often not "faithful" to "real" IOSs.
Even "real" IOSs can have different behaviors between versions (and platforms).
I.e. the only way I've found, with 100% certainly, how a particular IOS version/platform will behave is by using that actual IOS platform/version .
