ACL between VLANs on 3560g
I need to configure access restrictions between VLANs in client's network. For some reason the ACLs configuration we have now does not make any difference as all traffic can freely flow between the VLANs. There are three VLANs:
2   DATA - 172.29.1.0/24
10 VOICE - 172.29.2.0/24
99 MANAGEMENT 172.29.99.0/24
Access should be allowed as follows:
admin host 179.29.1.45(vlan2) should have access to all hosts in vlan 10 on the following ports: icmp, ssh, web, 10000
everything else between these vlans should be denied
only admin host 179.29.1.45(vlan2) should have access to vlan 99. Everything else between these vlans should be denied.
The LAN network include 3560g core switch (where vlans are configured), 2590 (vtp) and linksys(manual vlans and trunks) data switches, 3COM and linksys voice switches (manual vlan configuration).
This access list is configured:
ip access-list extended PC_VOIP
permit icmp host 172.29.1.45 172.29.2.0 0.0.0.255
permit tcp host 172.29.1.45 172.29.2.0 0.0.0.255 eq www
permit tcp host 172.29.1.45 172.29.2.0 0.0.0.255 eq 10000
permit udp host 172.29.1.45 172.29.2.0 0.0.0.255 eq 22
permit tcp host 172.29.1.45 172.29.2.0 0.0.0.255 eq 22
And applied like this:
interface Vlan10
ip address 172.29.2.250 255.255.255.0
ip access-group PC_VOIP in
Does it look correct? Unfortunately I still can telnet from vlan2 to vlan10 even though it's not allowed in the access list. Please advise. Thanks.
Here is the config of the core switch:
version 12.2
no service pad
service sequence-numbers
hostname 5-c3560g-core
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
authentication mac-move permit
ip routing
spanning-tree mode pvst
spanning-tree vlan 1-2,10 priority 4096
vlan internal allocation policy ascending
interface Port-channel1
switchport mode trunk
interface Port-channel2
interface Port-channel3
interface Port-channel4
interface GigabitEthernet0/1
switchport access vlan 2
switchport mode access
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
description TEST VOICE PORT
interface GigabitEthernet0/14
description TELEPHONY SERVER
switchport access vlan 10
interface GigabitEthernet0/15
description TRUNK TO VOICE ACCESS SWITCH 2 Linksys
channel-group 4 mode active
interface GigabitEthernet0/16
interface GigabitEthernet0/17
description TRUNK TO VOICE ACCESS SWITCH 1 3COM
channel-group 3 mode active
interface GigabitEthernet0/18
interface GigabitEthernet0/19
description TRUNK TO DATA ACCESS SWITCH 2
channel-group 2 mode active
interface GigabitEthernet0/20
interface GigabitEthernet0/21
description TRUNK TO DATA ACCESS SWITCH 1
channel-group 1 mode active
interface GigabitEthernet0/22
interface GigabitEthernet0/23
description FIREWALL VOICE INTERNAL INTEFRACE
interface GigabitEthernet0/24
description FIREWALL DATA INTERNAL INTERFACE
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
no switchport
no ip address
interface GigabitEthernet0/28
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 172.29.1.253 255.255.255.0
interface Vlan10
ip helper-address 172.29.2.50
interface Vlan99
ip address 172.29.99.253 255.255.255.0
ip classless
ip http server
ip http secure-server
end
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
Re: ACL between VLANs on 3560g
I believe your PC_VOIP ACL shall be configured on the VLAN2 interface in the inbound direction, not on the VLAN10 interface.
The concept is somewhat confusing but essentially very logical - the SVIs (interface Vlan2, interface Vlan10) behave just like any other router interfaces. If a PC in VLAN2 sends a packet that goes somewhere outside the VLAN2, this packet will be inbound to the interface Vlan2. It is true that you want to limit packets entering the VLAN10 but from the viewpoint of the interface Vlan10, packets are going out the interface Vlan10 and thereby flowing into VLAN10.
Does this make any sense?
Best regards,
Peter
Hi Andri,
it would also control access to the VLAN 99 as required, so I need only one ACL?
Yes, you can do it that way. In general, an ACL placed on an inbound direction of an interface applies to all packets coming into that interface, headed towards any destination network. Because an interface can have only one ACL in a particular direction, you need to perform input filtering in a single ACL.
If so do I need to add the following line at the end?
deny ip any any
Technically, it is not necessary because each ACL ends with an implicit "deny any". Despite that, many experienced administrators like to have this line at the very end of an ACL because of various reasons: to explicitly declare that the policy of the ACL is "drop all that is not permitted explicitly", to make sure that inadvertent additions to the ACL do not have any effect (because they are placed after this line) and simply to have the entire behavior of the ACL defined explicitly, instead of relying on a built-in implicit behavior.
Also, is separate ACL required to block access in opposite direction, from VLAN 10 to VLAN 2?
Yes. An ACL placed on the Interface Vlan2 in the in direction filters all the traffic coming into that interface. It does not filter packets that are leaving the interface in the out direction. In order to have control over both directions of data flow, you need to place additional ACLs on your interfaces.
Best regards,
Peter
Best regards,
Peter
Hi Peter,
Thanks for your answer. I really hope that it makes sense!   So presumably by adding an extra line to this ACL:
permit ip host 172.29.1.45 172.29.99.0 0.0.0.255
deny ip any any
Thanks.
Andri
Hi Andri,
deny ip any any
Best regards,
Peter
Thanks for clear answers. This is very helpful.
However, this brings another question. One thing I don't understand is why the ACL on interface vlan10 didn't block all traffic when was applied? Is this correct that the default line deny ip any any at the end of the ACL applied to VLAN 10 should have blocked my telnet session from VLAN 2 to VLAN 10? Please advise.
Many thanks.
Andri
Hello Andri,
Frankly, I don't know. The ACL per itself should have actually disabled all traffic going from VLAN10 to another VLANs because it was applied to incoming traffic from VLAN10, trying to match source/destination that are not even present in the VLAN10. Most certainly, adding the deny ip any any is not required.
I wonder - what is your current SDM setting (partitioning of the TCAM among various applications)? Can you post the show sdm prefer command output here?
Best regards,
Peter
Hi Peter,
Sorry for the delay, I was just visiting this client. Basically it's all good. I was following your advise and everything works perfect. I needed to figure out a few bits about the ACL for VLAN10 though. Because the rules should start with hosts addresses from vlan 10 and its ports.
Many thanks for your advise, it helped a lot!
Best wishes,
Andri
Here is what I added:
interface Vlan2
ip access-group PC_USERS in
interface Vlan10
ip address 172.29.2.253 255.255.255.0
ip access-group VOICE_TO_DATA in
interface Vlan99
ip access-list extended PC_USERS
permit tcp 172.29.1.0 0.0.0.255 172.29.2.0 0.0.0.255 eq www
permit tcp host 172.29.1.45 host 172.29.2.50 eq 139
permit tcp host 172.29.1.1 host 172.29.2.50 eq 139
permit udp host 172.29.1.45 host 172.29.2.50 range netbios-ns netbios-dgm
permit udp host 172.29.1.1 host 172.29.2.50 range netbios-ns netbios-dgm
deny   ip 172.29.1.0 0.0.0.255 172.29.2.0 0.0.0.255 log
deny   ip 172.29.1.0 0.0.0.255 172.29.99.0 0.0.0.255 log
permit ip any any
ip access-list extended VOICE_TO_DATA
permit icmp 172.29.2.0 0.0.0.255 host 172.29.1.45 echo-reply
permit tcp 172.29.2.0 0.0.0.255 eq www 172.29.1.0 0.0.0.255
permit tcp host 172.29.2.50 eq 139 host 172.29.1.45
permit tcp host 172.29.2.50 eq 139 host 172.29.1.1
permit udp host 172.29.2.50 range netbios-ns netbios-dgm host 172.29.1.45
permit udp host 172.29.2.50 range netbios-ns netbios-dgm host 172.29.1.1
permit tcp 172.29.2.0 0.0.0.255 eq 10000 host 172.29.1.45
permit udp 172.29.2.0 0.0.0.255 eq 22 host 172.29.1.45
permit tcp 172.29.2.0 0.0.0.255 eq 22 host 172.29.1.45
deny   ip 172.29.2.0 0.0.0.255 172.29.1.0 0.0.0.255 log
deny   ip 172.29.2.0 0.0.0.255 172.29.99.0 0.0.0.255 log
permit ip any any
3943
