07-12-2008 06:19 AM - edited 03-06-2019 12:09 AM
I applied two ACL (in-out)in my interface vlan in a 6506-E router to restrict some connections in my network; ACL are working fine but ACL counters don't show hits those match, only the deny line at the end shows counters increasing.
Is it the correct way to apply ACL in a interface vlan (layer 3) in a WS-6500-E?
Please, let me know your comments.
TIA.
07-12-2008 08:22 AM
That's expected in the 6500 as packets are fast-switched, not process-switched.
HTH,
__
Edison.
07-12-2008 09:09 AM
Have you tried the following command?
Switch#show tcam interface Vlan3 acl in ip
07-14-2008 06:01 AM
Thanks, I can see the information I need.
