08-09-2010 04:07 AM - edited 03-06-2019 12:22 PM
Hi all,
I have two 2960 cisco switch and 1 cisco catalyst 3750.
I configure the 3750 as the main core.
Here's the configuration:
interface GigabitEthernet1/0/1
switchport mode trunk
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface Vlan1
no ip address
interface Vlan2
ip address 192.168.73.64 255.255.255.0
interface Vlan3
ip address 172.17.3.125 255.255.0.0 secondary
ip address 192.168.72.64 255.255.255.0
interface Vlan4
ip address 192.168.74.64 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 172.25.74.71
ip http server
and here's the configuration of the 2960 switch:
interface GigabitEthernet0/1
switchport access vlan 2
switchport mode access
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/5
interface GigabitEthernet0/6
switchport access vlan 3
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
switchport access vlan 4
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/19
Switch(config)#s
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
Connected on 2960 are two laptops. One pc is for vlan 2 and the other one is on vlan 3.
On packet tracer both pc can ping each other. But on the actual appliance both laptops can't see each other.
What is the possible cause of that.
I need them to see each other but i don't know what's wrong with it.
Both laptops can ping the ip set on vlan 2 to vlan 4.
Please help I badly needed it....
Solved! Go to Solution.
08-09-2010 04:23 AM
Is IP routing enabled on 3750..??
Enable it using command " ip routing"
Hitesh Vinzoda
Pls rate useful posts
08-09-2010 06:01 PM
On the 3750 make sure IP routing is turned on. Also make sure you have the correct gateway configured on each PCs
config t
ip routing
08-09-2010 04:23 AM
Hitesh Vinzoda
08-09-2010 04:27 PM
yes ip routing is enabled.
my command is:
what ip route command should i use?
08-09-2010 05:11 PM
You mentioned that you are able to ping both the PC from one another, is that correct ? If yes then it looks like an application issue.
See if your firewall is blocking this application or something like file-sharing is not enabled?
Hope that helps.
08-09-2010 05:54 PM
nope. my problem is that both pc can not ping each other.
I need them to see each other.
08-09-2010 05:13 PM
If both laptops can ping each other than that means your routing is working. Now if you have any resource on one of the laptops and you are trying to access it, than you need to share that drive ie C or D drive, and then you should be able to see it from the other laptop. Is this what you are looking for?
Reza
08-09-2010 05:55 PM
the problem is that both laptops can not ping each other but they can ping each others gateway.
What will be the problem?
thank you
08-09-2010 06:01 PM
config t
ip routing
08-09-2010 06:37 PM
thank you so much your advise help me a lot
