ACL on a 10G Ethernet port on a VS-S720-10G Card
I am trying to apply an ACL on a 10g ethernet port on a VS-S720-10G card but it's not showing on the options. Is the port ACL a supported option on the 10g ethernet port on a sup 720 card?.
Hall of Fame Super Blue
Re: ACL on a 10G Ethernet port on a VS-S720-10G Card
Well according to Table 3 in this link yes they are supported -
http://www.cisco.com/en/US/customer/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a0080159856_ps2797_Products_Data_Sheet.html
so not sure why there are not an option. How have you configured the port ie. L2 switchport or L3 routed port ?
if a L2 switchport is it configured as a trunk ?
Jon
The port is configured as a trunk and a L2 port. This is the configuration of the port
switchport trunk allowed vlan xxxx,xxxx,xxxx
switchport mode trunk
switchport nonegotiate
no snmp trap link-status
and these are the options I see when under the interface config (looking for ip access-group)
router2(config-if)#ip ?
Interface IP configuration subcommands:
  admission           Apply Network Admission Control
  arp                 Configure ARP features
  auth-proxy          Apply authenticaton proxy
  dhcp                Configure DHCP parameters for this interface
  dhcp                DHCP
  header-compression  IPHC options
  igmp                IGMP interface commands
  rsvp                RSVP interface commands
  rtp                 RTP parameters
  verify              verify
  vrf                 VPN Routing/Forwarding parameters on the interface
Thanks.....
Can you add this to the port configuration -
int xxx
access-group mode prefer port
and then see if the "ip access-group ..." is available.
Jon
Jon,
There is still no option to configure ip access-group when configuring the trunk port with the access mode preferred port configuration.
Chris
ip access-group is for layer 3 interfaces.  Either change the layer 2 interface to layer 3 with "no switchport" or put the ACL on the SVI
Kathleen,
Thanks for the reply but as per documentation on the 6509 and on the 12.2SX IOS, Port ACL on Layer 2 is supported.
Jon,
Additional information is that it is not just on the 10G ethernet port that we are not seeing the "ip access-group option". It is not also showing up on the 1 g interface ports that is configured as a trunk.
The "ip access-group" option does show up though on a 4900M Line card but configured as private-vlan trunk.
Chris
Sorry about that last post, you're right.  What version are you running?  From this doc it looks like you need SXI
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1053880
With some exceptions, the VSS has feature parity with the standalone Catalyst 6500 series switch. Major exceptions include:
In software releases earlier than Cisco IOS Release 12.2(33)SXI2, the VSS does not support IPv6 unicast or MPLS.
In software releases earlier than Cisco IOS Release 12.2(33)SXI, port-based QoS and port ACLs (PACLs) are supported only on Layer 2 single-chassis or multichassis EtherChannel (MEC) links. Beginning with Cisco IOS Release 12.2(33)SXI, port-based QoS and PACLs can be applied to any physical port in the VSS, excluding ports in the VSL. PACLs can be applied to no more than 2046 ports in the VSS.
495
