ACL on switch ports
I have 2 switches available to use, a 2960 or 2950. Ideally I wish to use the 2950 if possible.
What I want to achive is for a few ports to be limted to Internet only traffic, and dns lookups from a selected internal dns server. So when a machine is plugged into one of these ports the user cannot see any of the internal network.
The setup of the site I need this for prevents me from using multiple vlans as everyone must be on the same /27 subnet.
Can this be done on a 2950 or 2960?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: ACL on switch ports
You can use the 2950 but there are quite a few limitations in terms of how many entries you can have in the acl. However  your acl could be very simple eg.
assuming your subnet was 192.168.5.0 255.255.255.224
access-list 101 permit udp host host eq 53
access-list 101 deny ip host 192.168.5.0 0.0.0.31
access-list 101 permit ip host any
then you apply it to the physical port -
int fa0/1
ip access-group 101 in
you should refer to this document for full details including all the restrictions/limitations -
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/configuration/guide/swacl.html#wp1082773
Jon
int fa0/1
Jon
Worked a treat, thank you
102
