ACL PROBLEM
Didier1966
I have a CISCO 1841 ROUTER (IP=192.168.1.250) and a CATALYST 2950 SWITCH (IP=192.168.1.251) in my test LAB.
Both are connected with a TRUNK , to share the same VLANS.
The problem is , when I connect to VLAN 10 or 20 or 30 , I am not able to PING the ROUTER or the SWITCH , this give me a problem to save the files to my TFTP server.
When I connect to F0/1 , I receive the right IP ADDRESS 192.168.10.x
When I connect to F0/2 , I receive the right IP ADDRESS 192.168.20.x
When I connect to F0/3 , I receive the right IP ADDRESS 192.168.30.x
ON ALL OF THEM I HAVE INTERNET
I am really new on the CISCO stuff ,but I studying a lot
Here bellow I give you a copy of the router config and the switch config :
SWITCH:
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
interface FastEthernet0/2
switchport access vlan 20
interface FastEthernet0/3
switchport access vlan 30
interface FastEthernet0/12
switchport mode trunk
interface Vlan1
ip address 192.168.1.251 255.255.255.0
no ip route-cache
ROUTER:
interface FastEthernet0/0/0
spanning-tree portfast
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
ip address 192.168.1.250 255.255.255.0
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip access-group 102 out
ip nat inside
ip virtual-reassembly
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface Vlan30
ip address 192.168.30.1 255.255.255.0
ip nat inside
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list 101 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.100.10 80 81.164.200.35 8095 extendable
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 permit ip 192.168.20.0 0.0.0.255 any
access-list 101 permit ip 192.168.30.0 0.0.0.255 any
access-list 101 permit ip 192.168.100.0 0.0.0.255 any
access-list 102 permit ip any any
no cdp run
I DO NOT KNOW IF THIS IS HELPFUL FOR THIS PROBLEM , BUT HERE YOU HAVE THE VTP :
ROUTER VTP :
ROUTER1841#sh vtp st
VTP Version                     : 2
Configuration Revision          : 12
Maximum VLANs supported locally : 19
Number of existing VLANs        : 8
VTP Operating Mode              : Server
VTP Domain Name                 : DRI
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0x4C 0x8D 0x3C 0x87 0x0A 0x11 0xFA 0xC7
Configuration last modified by 192.168.1.250 at 11-29-10 18:57:03
Local updater ID is 192.168.1.250 on interface Vl1 (lowest numbered VLAN interface found)
SWITCH VTP:
SWITCH2950-12#sh vtp status
VTP Version                     : 2
Maximum VLANs supported locally : 128
VTP Operating Mode              : Client
Thank You In Advance AGAIN for your help
Best Regards,
Didier
2 Accepted Solutions
Richard Burts
Didier
You show us only part of the router confg and that makes it difficult to understand some of what is going on. For example you show us several interfaces configured with ip nat inside, but show nothing that is ip nat outside.
You also do not show us anything about the routing logic on the router. And you do not tell us where the TFTP server is located.
There is also some inconsistency that puzzles me. You show ip nat inside on vlan10, and vlan20 and vlan 30 but not on vlan 1. Is there a reason for that?
Even though there are many things that we do not know which would be helpful, I am going to make a guess at the problem. I guess that the problem has to do with address translation and with the fact that the access list which identifies traffic to be translated (access list 101) permits all traffic from networks 192.168.10.0, 192.168.20.0, 192.168.30.0, and 192.168.100.0 to any destination to be translated. I guess that if you re-write the access list and first deny traffic from these networks to the network of the TFTP server and then permits the networks to any destination that your problem may be solved.
Give this a try and let us know what happens.
Rick
Rick
Didier
I wish that it were completely normal to post to the forum when you find a solution to a problem. But my experience is that not everyone does this. And I agree with you that this results in time being wasted.
There is confusion about the button that I refer to as solved. Perhaps now it says answered or something like that. But in my post there is a green check mark on a yellow background which is the indication that the response answered (or solved) the issue. The original poster is the only one who can give that mark, and it looks like you did. The check mark shows up in the listing of the discussions (when you have logged in to the forum) and is the indicator to other readers that the issue is answered (or solved).
Rick
Rick
8 Replies 8
tomscookin
Isolate this down just a bit.  Pick 1 single port to connect your PC to, and troubleshoot starting from there.
For example, plug in to the vlan10 port (f0/1) ... and try to ping the vlan10 ip address of the router:  192.168.10.1
Does this work?  If so, then that address should be your default gateway on the pc ... Is it?  If so, then you should also be able to ping the other IP addresses from that port.
The router/switch "ips" are on vlan 1 ... which is different than what you are putting your PC on, so your gateway address must be a device that can route you to the destination vlan.
Can you be a little bit clearer which ip can't you ping from which ip?
Regards.
Richard Burts
Didier
Rick
Rick
Hello All,
Thank you for your prompt reaction
Sorry if I was not clear enough , but bellow you have the FULL WORKING ROUTER configuration.
When I connect my computer that is ALSO the TFTP SERVER (just for upload and download) , I receive :
On F0/0/0 = 192.168.10.x     PING 192.168.10.1 is OK
On F0/0/2 = 192.168.20.x     PING 192.168.20.1 is OK
On F0/0/3 = 192.168.30.x     PING 192.168.30.1 is OK
F0/0/4 is the TRUNK to the SWITCH
The ROUTER has a IP 192.168.1.250
The SWITCH  has a IP 192.168.1.251
From IN IOS I can PING : 192.168.1.250 and 192.168.1.251
But from one of the 3 VLANS (192.168.10.x or 192.168.20.x or 192.168.30.x) the ping does not work , so I presume something is wrong in my ACL ?!?
NOTE : I DO NOT NEED TO HAVE ACCES FROM ALL , IF I HAVE ACCES FROM ONE IT IS OK, I just need to have access to copy the file from my SWITCH to my COMPUTER (TFTP SERVER)
Thank You Again for your help. I hope that one day I will understand how the logic of ACL works
! Last configuration change at 21:02:50 gmt+1 Mon Nov 29 2010 by admin
! NVRAM config last updated at 23:06:14 gmt+1 Mon Nov 29 2010 by admin
version 12.4
service password-encryption
hostname ROUTER1841
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable password 7 05080F1C2243
aaa new-model
aaa authentication banner
THIS SYSTEM IS SOLELY FOR USE OF AUTHORISED USERS FOR OFFICIAL PURPOSES
aaa session-id common
clock timezone gmt+1 1
clock summer-time gmt+2 recurring last Sun Mar 2:00 last Sun Oct 3:00
dot11 syslog
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp excluded-address 192.168.30.1
ip dhcp excluded-address 192.168.100.1
ip dhcp pool vlan10
   import all
   network 192.168.10.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.10.1
   lease 5
ip dhcp pool vlan20
   import all
   network 192.168.20.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.20.1
   lease 5
ip dhcp pool vlan30
   network 192.168.30.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.30.1
ip dhcp pool FIX-IP
   host 192.168.100.66 255.255.255.0
   client-identifier 0100.089b.ad17.8f
   client-name FIX-IP
ip dhcp pool TEST
   host 192.168.100.20 255.255.255.0
   client-identifier 0100.2241.353f.5e
ip dhcp pool internal
   network 192.168.100.0 255.255.255.0
   dns-server 192.168.100.1
   default-router 192.168.100.1
no ip bootp server
ip domain name dri
ip ddns update method DynDNS
HTTP
  add http://dri66:@members.dyndns.org/nic/update?system=dyndns&hostname=cisco1841.dyndns.info&myip=
interval maximum 1 0 0 0
interval minimum 1 0 0 0
username Admin privilege 15 secret 5 $1$gAFQ$2ecAHSYEU9
archive
log config
  hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh port 8096 rotary 1
ip ssh version 2
description DMZ
ip ddns update hostname cisco1841.dyndns.info
ip ddns update DynDNS
ip address dhcp
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
description INTERNAL$ETH-LAN$
ip address 192.168.100.1 255.255.255.0
no ip proxy-arp
ip nat inside
duplex auto
speed auto
interface Vlan1
interface Vlan10
ip nat inside
interface Vlan20
ip nat inside
interface Vlan30
ip nat inside
ip forward-protocol nd
ip http server
ip dns server
no cdp run
control-plane
banner exec
WELCOME YOU ARE NOW LOGED IN
banner login
WARNING !!!
IF YOU ARE NOT :
Didier Ribbens
Please Leave NOW !!!
YOUR IP and MAC address will be LOGGED !!!
line con 0
speed 115200
line aux 0
line vty 0 4
access-class 5 in
privilege level 15
rotary 1
transport input telnet ssh
line vty 5 15
access-class 5 in
rotary 1
scheduler allocate 20000 1000
ntp clock-period 17178446
ntp server 66.27.60.10
end
SWITCH:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SWITCH2950-12
username Admin privilege 15 secret 5 $1$qMty$HAjO6PjGEwDDl2FYHqnSY.
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface Vlan1
no ip route-cache
ip default-gateway 192.168.1.254
ip http server
line con 0
password 7 130105040606167C7D04
login
speed 115200
line vty 0 4
privilege level 15
password 7 050F14192C465C5F4F25
login local
line vty 5 15
privilege level 15
login local
ntp clock-period 17178532
end
I JUST FOUND THE PROBLEM :
THE DEFAULT GATEWAY IN THE SWITCH WAS WRONG !!!
IT HAS TO BE :
192.168.1.250 AND NOT 192.168.1.254
Best Regards,
Didier
Didier
I am glad that you got it working - and that you found the solution yourself. Thank you for posting back to the forum to inform us that you had solved it and what the problem was. It makes the forum more useful when people can read about a situtation and can read what the problem was and how it was solved. You have contributed to this and provided a reminder that sometimes it is simple things like is the gateway address correct that is the root of the problem.
Rick
Rick
Hello Rick,
I think that it is completely normal to post a reply when the case is solve , your time is really too expensive to spend it with a case that is already solved.
During this time you can maybe help someone that has a bigger problem.
In this forum , I miss the button solved , or maybe I do not know where it is
Best Regards,
Didier
Didier
Rick
Rick
