Webcast-Catalyst9k
ACL restriction on switched network
Hi gents,
Which type of ACL should i use to get some ip subnets in restricted L2(swithed) environments?
I cant use mac ACL, as i have a lot hosts.Can't use VLAN ACL either.There are
some restrictions.
thanks
Leo
Hall of Fame Super Blue
Re: ACL restriction on switched network
Leo
Could you clarify what you are trying to do exactly.
Jon
I have SwitchA connected to SwitchB.
They connected to each other through switched port (access port)vlan 20.
There are a some servers in Vlan20 connected to SwitchB
SWitchB has the route to ISP.
SwitchA- Interface Vlan 20
ip address 10.20.0.1
default gateway - 10.20.0.254
SwitchB - Interface Vlan 20
IP address 10.20.0.254
default gateway - Internet Gateway
SwitchA has vlan16 - 10.16.0.0
Hosts from this subnet access the internet through SwithB and then SwithA.(and also can see servers in vlan 20)
SwitchB- doesn't have vlan 16
It has has onlu back route to that subnet.
How can i restrict 10.16.0.0 access to 10.20.0.0 servers?
Outbound ACL on interface Vlan20 SWitchB?
thanks?
Sorry...Correction.
Hosts from this subnet access the internet through SwithA and then SwithB.(and also can see servers in vlan 20)
Outbound ACL on interface Vlan20 SwitchA?
Hi Leo
Do you have an SVI on switch A or vlan 16 then ? I guess you must be. You could apply the following acl on vlan 16 on switch A
access-list filter deny ip 10.16.0.0 255.255.0.0 10.20.0.0 255.255.0.0
access-list filter permit ip 10.16.0.0 255.255.0.0 any
On vlan 16 interface
ip access-group filter in
The destination network from the 10.16.x.x hosts will be always be allowed unless it is going to a 10.20.x.x address.
If there are some addresses in the 10.20.x.x range that you want access to from 10.16.x.x clients you could add those to the top of the access-list.
Jon
Hi, apply extended ACL on vlan 20 interface as inbound & define 10.16.0.0 as source & destination 10.20.0.0.
If it helps do rate it.
Ninja
130
