06-01-2009 01:24 AM - edited 03-06-2019 06:01 AM
Hi All,
I need to add comment for ACL's (rule) to know others exactly what rule functioning what.
For example there is a ACl (rule) like...
#permit ip host 192.168.xxx.xx host 10.xx.x.xx
Here I what add comment for this rule like....
Thanks in advance,
Naidu.
06-01-2009 02:21 AM
Hi Naidu
Check out this link
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t2/feature/guide/comment.html
for information on adding comments to ACL's on Cisco equipment.
HTH.
Best Regards,
Michael
06-01-2009 04:20 AM
Hi Michael,
Thanks for your response.
Thats ok, but what i want is both access-list command as well comment should in single line like....
#permit ip 10.XX.X.X 0.0.255.255 any (Aalborg network can access any outisde network)
Naidul
06-01-2009 07:44 AM
Naidul
I believe that the suggestion from Michael is your best option. While I can agree that it would be nice to have the comment and the the rule in the same line I do not believe that IOS supports this.
Rick
