ACL(s) for Same VLAN Traffic
michaelyentsch
Hi, I'm using a Cisco 2960 and I'm trying to create an ACL to block communication to and from specific IPs. More specifically, I want to block communication to other hosts on the same VLAN. All other traffic should be able to get in/out. I've been testing by creating some extended and standard ACLs but I'm unable to have them affect the traffic inside the VLAN.
Do I need to be using VLAN access maps? If so, would someone be able to provide some syntax and/or explain how to implement them? I'm not too familiar with ACLs.
Thanks, in advance.
Ah, you the man. This blog did a great job at clarifying things for me. Not an information overload, but hit all the importants points.
Thanks!
Annnnnd not that anyone really cares, but I got this working on my test switch thanks to KWillacy's help. Then I found that the production switch for which I was running these tests doesn't support VACLs....
*womp womp wommmmmmpp*
Oh too bad, at least it worked
