ACL to block broadcast and multicast on one switch port
stefan-stefan
This is probably going to be a very easy question for most of you but it would help me quite a bit.
What I want on one of our 3560 series switches is to prevent any broadcast and multicast traffice going to a port.
The reason for this is that there is a router behind it (not ours but supplied by our telecom company) which makes a connection to another office and I want the line (as its not a very big one) to be as clean as possible.
Its probably going to be something like this but just not sure if this is correct :
access-list 10 deny 255.0.0.0 0.255.255.255
access-list 10 deny 224.0.0.0 7.255.255.255
access-list 10 permit any
Thanks!
9 Replies 9
So should I use protected ports instead ?
The article doesn't mention ACL's.
I was thinking more along the lines of port blocking, this will block multicast and unicast.
Remember a router will NOT forward broadcasts.
Stefan,
Do you really want to do that way? (grin)
Switch(config)# interface gigabitethernet X/Y
Switch(config-if)# storm-control multicast level 0
Switch(config-if)# storm-control broadcast level 0
Let's start from here: http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swtrafc.html
HTH,
Toshi
I am just looking at this document for a similar requirement as the original post - but isn't storm control for Ingress traffic?
Correct - do you think that a switch just generates broadcast/unicast.multicast packets itself??
They HAVE to come IN from a port.
Sure - but the original post was about not forwarding this traffic OUT through a specific port, so Egress (something I want to do) but dont think this is possible?
if you do this
Then no more traffic will enter the port as soon as multicast packet enters the port   because storm-control for multicast wiil block unicast also when the threshold is hit.
Alain.
kishan1984
try enabling igmp snooping(default is enable) and also type one command to enable switch to itself function as a igmp querier.
