ACL
Hi All,
Can anyone help me to understand the below access-list
access-list zzz permit ip host yy.xx.224.0 host 255.255.252.0
Anantha Subramanian Natarajan
Re: ACL
The other IP can't be 255.255.252.0
what you want to know exactly. Any particular thing or full command (how it works)
Re: ACL
Hi Manish,
Thanks for the reply .....
I found the access-list in this format on a route-map which is associated with BGP in inbound. I was thinking if the intent for this access-list is to allow yy.xx.224.0/22 ,it should have been access-list zzz permit ip yy.xx.224.0 0.0.3.255 any.
Is the above right ? .If this is , then i am as trying to invalidate the existing ACL.
Re: ACL
Ya thats the right command to allow yy.xx.224.0/22 to any.
Re: ACL
Hi manish,
Hall of Fame Super Silver
Re: ACL
Anantha
Perhaps if we knew a bit more about the context in which this access list was configured we might understand it better.
If you assume that it is a typical access list configured to filter data traffic on an interface then it makes little sense, especially with the destination address being 255.255.252.0.
However if this access list were configured and used as part of a distribute list in the configuration of BGP then it would make a lot more sense. If BGP this access list used in a distribute list would permit BGP to accept or to advertise (depending on whether it was inbound or outbound) network yy.xx.224.0 with a /22 mask.
While we usually think of distribute list using a standard access list (as it does in RIP or EIGRP - or even OSPF) in BGP you can use an extended access list where you may want to specify both the network and the network mask.
[note] I see in the response posted just as I was writing my response that this is used for BGP. In this case the access list is valid as written.
Rick
Re: ACL
Hi Rick,
Thanks for the reply.....So do you mean, the below command
access-list zzz permit ip host xx.yy.224.0 host 255.255.252.0
when associated to route-map which is then called in bgp inbound,then it means to match xx.yy.224.0/22 ?
Re: ACL
Anantha
Yes it will match on both the network prefix value (xx.yy.224.0) and on the mask (/22).
If you change the access list to access-list zzz permit ip yy.xx.224.0 0.0.3.255 any then you will seriously change the function of the access list. And if the previous version of the access list was working then the new version of the access list will break some part of your BGP impelmentation.
Rick
Re: ACL
Hi Rick,
Good explanation..Thanks .....Then the thing which I couldn't understand is the how the existing ACL works.
I am thinking,the existing ACL will match packet from specific source xx.yy.224.0/32 comming from specific host 255.255.252.0/32.Is that right ??..Sorry to take your time on this..But me missing some basic on it ..
Re: ACL
Hi Rick,
Just a correction on above understanding ...instead of from ,use to to host 255.255.252.0/32
Re: ACL
Anantha
No that is not right. We typically think of extended access list as specifying source-address, source-mask, destination-address, destination-mask. But the definition of the parameters is quite different when an extended access list is used for BGP. In this usage the parameters have this meaning network-prefix, #-significant-bits, prefix-mask, #-significant-bits)
So it works very differently in BGP than it does in normal access list usage.
Rick
Re: ACL
Hi Rick,
Thats awesome,,Can you please refer me to some link,which explains that ......
Once again ,thank you very much
Re: ACL
Anantha
This tech note has a discussion of using extended access lists in the distribute list for BGP:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00801310cb.shtml#acclists
Rick
Re: ACL
Hi Rick,
Thank you very much
148
