10-09-2013 10:29 AM - last edited on 03-25-2019 04:26 PM by ciscomoderator
hi,
i have currently been told to test a network layout. i have configured
5 vlans - vlan2,vlan3,vlan4,vlan5,vlan6 on a 3750 L3 switch. this is connected to three L2 switches in which the same vlans are created. enabled ip routing and now trying to configure access lists. but this is driving me crazy!!
int vlan2
ip address 172.16.0.0 255.255.255.128
int vlan3
ip address 172.16.0.128 255.255.255.128
int vlan 4
ip address 172.16.1.0 255.255.255.128
int vlan 5
ip address 172.16.1.128 255.255.255.128
int vlan 6
ip address 172.16.2.0 255.255.255.128
REQUIREMENT:
vlan 2 and vlan3 needs full access to vlan4
vlan5 needs access to only one ip in vlan4
vlan 6 does not need access to any other vlan.
what i have done so far with access control;
I
ip access-list standard vlan6
deny any
int vlan 6
ip access-group vlan6 in
ip access-group vlan6 out ## here no issues because there is no inter vlan access required.
II
ip access-list standard vlan4
permit 172.16.0.0 0.0.0.127
permit 172.16.0.128 0.0.0.127
int vlan 4
ip access-group vlan4 ## this never woked.. also tried with an extended list allowing the whole vlans2 and 3 subnets to vlan4 and then
## applying it to int vlan 4. that also never works.
III
ip access-list standard vlan5
permit host 172.16.1.10
int vlan 5
ip access-group vlan5 out ## this also never works.
please let me know where am i going wrong??
Solved! Go to Solution.
10-09-2013 11:04 AM
access-list 100 permit ip any 172.16.1.0 0.0.0.127
access-list 100 deny ip any any
access-list 101 permit ip any host 172.16.1.x
access-list 101 deny ip any any
int vlan2
ip access-group 100 in
int vlan3
int vlan5
ip access-group 101 in
Alain
10-09-2013 11:04 AM
int vlan2
int vlan3
int vlan5
Alain
10-09-2013 11:45 AM
hi alain,
thanks a lot. you are amazing!! it worked like a charm and relieved my stress. can you plz also explain how it works.
because when you say
the source is any and destination is 172.16.1.0.0. why it did not work with
sorry if i am being too silly but the point is i want to get it in my head somehow and make my job simple.
