Community Member
ACLs ... to ip or not to ip ....
I'm sure this has been asked before, but it has bugged me for sometime now.
What is the difference between
R1(config)#access-list 12 permit 192.168.6.0 0.0.0.255
and
R1(config)#ip access-list standard 12
R1(config-std-nacl)#permit 192.168.6.0 0.0.0.255
Using access-lists with and without the ip keyword has always confused me.
I find that if I use the first method above, the distribute-list command that I use when apply redistribution filters works (distribute-list 12 out ospf 1
). However if I use the second method to create my ACL, the command is accepted but the fitlering fails.
Can someone clarify once and for all the difference between the two and when/why I should use one over another?
Everyone's tags (2)
1 REPLY
VIP Super Bronze
The 2 access-list are the same except with the second one you can actually name the access list instead of using a number.
example:
Switch(config)#ip access-list standard test
Switch(config-std-nacl)#permit 172.16.1.1
Switch(config-std-nacl)#permit 172.16.1.2
Switch(config-std-nacl)#permit 172.16.1.3
Switch(config-std-nacl)#do sh access-list test
Standard IP access list test
    10 permit 172.16.1.1
    30 permit 172.16.1.3
    20 permit 172.16.1.2
Not sure why your second one is not filtering correctly.
174
