Community Member
active and hot 10g supervisor module behavior
If I have one access 6509 switch connected to 2 core 6509 switch as follows..
Switch a - dual 10g sup..
slot 5 -- Active
slot 6 - Hot
Slot 5, supA-connected to core 1
Slot 6 , sup B- connected to core 2.
Running MST spanning tree
Since slot 5 is active, I expected my traffic to be following through there primarily.
But if I lose my link from core 1 to supA, will traffic then kick over to supB even though it's only in 'hot' mode ? I'm getting conflicting answers...
due to port count restriction on my core switches, I cannot do one link to core 1 and one link to core 2
on supA and the same on supB.
I also cannot do a full layer 3 to the core for now.
thanks
all
Community Member
Re: active and hot 10g supervisor module behavior
Hi there, I believe there may be some mis-understanding regarding the redundancy of the supervisors. In order to force the redundant supervisor to forward frames you need to make the hot sup process traffic.
Community Member
therein lies my problem. Is that possible ?how do you make a 'hot' module take over if the active module is still 'active' but the link to on the 'active' module drops....
Community Member
I would recommend reading through the 6500 configuration guide. I have linked you directly to the redundancy configuration section.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/nsfsso.html
Community Member
I think what you are implying is that unless I manually flip the secondary sup to make it active, there is no automatic redundancy.
148
