Community Member
Active/Standby SUP720 swap after reload
I have two SUP720 supervisors in a 6509 running
s72033_rp-IPSERVICESK9-M 12.2(18)SXF11.
When I am on the console of the active supervisor and I issue a reload command the switch reboots but the module that I am on boots as the standby module.
I then have to swap console cables to the other SUP720. If I restart the switch by power it on and off the active/standby modules stay the same and do not change.
Any ideas?
Thank you in advance,
Michael Krygier
Blue
Re: Active/Standby SUP720 swap after reload
Michael:
When you issue the reload command on the active SUP module, it actually doesnt start the reboot process until a split second after the other SUP because it is responsible for issuing the command and placing it on the system bus. So, it doesnt start reloading until a few ms later.
When you power the switch off, its a clean start for both.
The first SUP to come online will be the active one.
Now, quite frankly, I have absolutely no idea if what I have just said is absolute nonsense, but it sounds good...may help you get by in a job interview. :-)
Hall of Fame Super Gold
Hi Michael,
This is a feature. It's very useful, say, you need to upgrade the IOS and you don't want any disruption. So you can, theoretically, reload the HOT module and still continue with traffic.
Hall of Fame Super Silver
Hello Michael,
This is the reason for having two supervisors on the same chassis.
It is how sup processors redundancy works
Hope to help
Giuseppe
683
