add ports from EHWIC
I have a 2921 router for BGP. Gi0/0 ans Gi0/1 are from ISPs. Gi0/2 is my local network.
I also have two EHWIC-D-8ESG ( Gi0/1/0-7 and Gi0/3/0-7).
How can I use those 16 ports in addition to Gi0/2 for my local network?
Thanks a lot!
Silver
Those ports are your
Those ports are your switchports on your router chassis - so understand them as "switch inside your router". Principles from switches work here also - you can configure only L3 SVI ports on them and then have some kind of similar behavior as your Gi0/2 routed port.
So make difference between these L2 switchports and your Gi0/2 routed port and that would be enough for you to know what setup you can accomplish.
HTH,
Dragan
HTH, Dragan
I'm far away..... :)So is it
So is it possible somehow to configure them for LAN instead of Gi0/2?
Silver
Offcourse Adrian - configure
Offcourse Adrian - configure vlans on it and put your ports in appropriate vlan and you're ready to go...more on:
http://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/geshwic_cfg.pdf
HTH,
Dragan
HTH, Dragan
46
