03-28-2007 04:21 AM - edited 03-05-2019 03:09 PM
I have an existing stack of 375012ts and 375048ts with IOS ver 12.1(19)EA1c among them 375012ts is a master now i have to add an 375048ts with IOS ver 12.2(25)SEE2 so please guide me what steps should i follow.
03-28-2007 04:46 AM
Please see the link below and go through it completly. This link will tell you whole things about managing the switch stacks with 3750's.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12235se/scg/swstack.htm
HTH,Please rate if it does.
-amit singh
03-28-2007 05:05 AM
thanks for your reply and will go thru as u suggested.
03-29-2007 10:17 PM
can you tell me what will be effect of replacing the switch 3750 24ts iso ver. from 12.2(25)SEE2 to 12.1(19)EAic will the switch will support the older iso version.
03-30-2007 06:14 AM
Upendra,
You can certianly run the older IOS on the switch. But why you want to do that ????
You might loose out some features that you are running on the switch rt now. Please the release notes for the older IOS and check for the features.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12119ea1/ol543002.htm
HTH,
-amit singh
