Hi everyone, I have a Cisco catalyst C1200-24P-4X switch, and I want to enable stacked VLAN configuration on it. Does it can support the feature?
The content you are looking for has been archived. View related content below.
I have Configured the 802.1x Configuration in WS-C2960X-24TS-LL Switch Globally. when i test the aaa test it was successful. but when i tried to configure in the Interface the authentication was not happening. so can you please help to configure the ...
Hi,I set up vlans, interface vlans with IPs, access ports, link aggregations and trunk on my Cisco 3172TQ.I also set up a linux machine as a test machine to check the configuration.If I send tagged traffic to the access ports of the switch, it seems ...
Hello, CML (Cisco Modelling Lab) 2.5 announced a virtual Catalyst 9000 running IOS-XE 17.10 - I tested this out on my personal CML 2.6.1 and I am struggling to get 802.1X working. I know Cat 9K virtual is still a beta release and the CML folks can't ...
I am trying to retrieve all IGMP snooping parameters and the associated multicast forwarding table from a 3850. From the q-bridge-mib, the multicast forwarding table is: dot1qTpGroupTable. But that mib does not appear to be supported. I even tried th...
I am trying to configure a trunk port on a Cisco 3750 that has fiber running to a ruckus 7150 switch.My current config connects the switches but it is only passing vlan1 traffic and I want multiple vlans. Therefore, I configured the port as a trunk o...
Hello, I would like to implement an ACL that would only allow returning traffic to the WEBTERM server ( initialised by the WEBTERM, no other traffic).The commands I used were :ip access-list extended REFLEXIVEpermit tcp any 172.16.30.0 0.0.0.255 esta...
Hello,I'm trying to figure out why Avaya Phones and PC's are showing up as both statically and dynamically learned. We do not have any mac addresses statically configured. Here is the output of a few ports.Cisco9300# show mac address-table int Gi8/0/...
I am configuring a DHCP Server for a small VLAN.I have configured vlan 10 20 30 and trunk access for switch interfaces, activated fa0/0.1, fa0/0.2, fa0/0.3 as example belowint fa0/0.1 encapsulation dot1Q 10 ip address 192.168.10.1 255.255.255.0 ip he...
Hello forum! We're working on a migration from voice service to webex and the team handling that has requested i find the LLDP chassis mac address and port Id. I'm trying to do this in the cli and the sh mac-address-table command shows a myriad of ad...
Hello All,I have a Cisco 1121-4P router running IOS XE 17.9.4a and I dont see the channel group option under any of the 4 switchports. The option shows up in WAN port, but I would like to utilize two switchports for the same VLAN and keep it under th...
hi friendsi config below commands to configure AAA authenticate with Microsoft Active Directory 2008(CIsco Device Integrate with AD microsoft for telnet and ssh and both can login to console by AD and local username) but while i unplugged Cisco Devic...
Good morning, On a Switch C2960X-24TD-L (UNIVERSALK9-M)(Boot loader C2960X), following a configuration error, I can no longer access the console in privilege mode.The only account available only allows me to access in user mode.I can't make any write...
I have a couple of switches that are trunked via a LAN cable from another switch. I noticed that these switches sometimes have a hard time to SSH into. I get the error: "Connection timed out". After a while and a few tries I can connect just fine. I ...
I have a few general questions when it comes to my network. Maybe someone could even suggest how to name the topic of my question. But firstly, I'd like to introduce you to my network. The special thing about the network is that subinterfaces are con...
Subject | Author | Posted |
03-28-2024 01:05 AM | ||
03-27-2024 03:07 PM | ||
03-26-2024 10:12 AM | ||
03-19-2024 05:09 AM | ||
03-18-2024 10:42 AM |
User | Count |
11 | |
11 | |
7 | |
6 | |
6 |
