07-08-2009 06:12 AM - edited 03-06-2019 06:38 AM
We currently have a routed connection to a site in a city accross the state.
The DR site is configured with a totally seperate VLAN config.
For example everything in the Main site is 10.100.x.x\24,
10.100.1.x\24 servers
10.100.2.x\24 printers
10.100.3.x\24 workstations
Remote site is 10.200.x.x\24
10.200.1.x\24 servers
10.200.2.x\24 printers
10.200.3.x\24 workstations
When we move from routed to Metro E to connect this site, is a trunk to the other site the way to go to connect the other site VLANs to the main site VLANS?
We have 5-060 VLANs in the main site and 20-30 VLANS in the remote site.
07-15-2009 05:42 AM
You can re-use Vlans on this scenario as the router will break the tag at ingress from the MetroE network and send it routed back to the internal network. At the internal network the switch connecting to this router can apply another Vlan tag or leave the incoming traffic from the router untagged.
Your Vlan allocation concern would be if the router is also doing 'router-on-a-stick' internally.
__
Edison.
07-15-2009 05:51 AM
Hi Edison,
So say the below config is you current router-on-a-stick configuration for a remote site (before ME implementation). And the provider gives you a vlan of say 200 to use. How could you arrange this config for the remote?
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.10.1.208 255.255.255.0
interface FastEthernet0/0.2
description DHCP AP's
encapsulation dot1Q 2
ip address 10.10.2.1 255.255.255.0
ip helper-address 10.40.2.3
ip helper-address 10.40.2.4
interface FastEthernet0/0.3
description fhmi$access
encapsulation dot1Q 3
ip address 10.10.3.1 255.255.255.0
interface FastEthernet0/0.6
description Static IPs
encapsulation dot1Q 6
ip address 10.10.6.1 255.255.255.0
interface FastEthernet0/0.7
description PBX
encapsulation dot1Q 7
ip address 10.10.7.1 255.255.255.0
Brandon
07-15-2009 05:56 AM
That's your internal facing interface. This router will need a ISP facing interface.
On the ISP facing interface, say F0/1
interface FastEthernet0/1
no ip address
speed 100
full-duplex
interface FastEthernet0/1.200
description ISP Native Vlan
encapsulation dot1Q 200 native
interface FastEthernet0/1.xxx
description point-to-point subnet for Hub
encapsulation dot1Q xxx
ip address x.x.x.x y.y.y.y
07-15-2009 06:02 AM
Hi Edison,
You're correct...still waking up I guess...;-).
Brandon
07-15-2009 10:54 AM
Edison,
In my scenario (from the top of post), I have two sites, with two different VTP domains.
Would you suggest that I add the reote site to the VTP domain in the main site, or leave it seperate?
I will be routing all but two or three VLANs (with the possibility of more later).
07-15-2009 11:06 AM
Up to you. If you want to add/modify/delete Vlans for remote site from a HQ VTP server, then configure the same VTP domain across.
I personally wouldn't do that. Have the remotes have a different VTP domain (Server/Client) from the HQ.
07-16-2009 04:12 AM
Thanks Edison.
What is the reason that you would leave it seperate?
07-16-2009 05:58 AM
It provides some kind of Vlan management security.
You don't want a mistake on Vlan creation/modification/deletion to get propagated to other switches.
We usually recommend running VTP transparent in a switched network. Note: This has nothing to do with MetroE but just a general concept.
HTH,
__
Edison.
07-17-2009 11:11 AM
I am not sure what you are saying about the VTP,
So, with two 6509 switches at the core network with several 3550 access switches,
All would be transparent?
Currently we have the two 6509s running VTP, one is server the other is client and the rest are transparent.
07-17-2009 10:52 AM
Hi Edison,
Just curious, but could you give a brief config or explanation of the configuration if you had a switch (6500) at the hub end instead of routers?
Brandon
07-17-2009 10:56 AM
Much easier;
interface gx/x
description MetroE connection
switchport mode trunk
switchport trunk native vlan [Metro_Vlan]
switchport trunk allow vlan [Metro_Vlan],[Common Vlans to be used for Remotes....]
interface vlan [remote 1]
description Site 1
interface vlan [remote 2]
description Site 2
07-17-2009 12:25 PM
Hi Edison,
So the HUB is a switch and the remotes are routers.
Would the interface on the remote routers sub interface pointing to the ISP (hand-off) reference dot1q of the vlan at the HUB?
Such as:
HUB switch:
interface gx/x
switchport trunk native vlan 500
switchport trunk allow vlan 500,150,160
interface vlan 150
description Site 1
ip address 10.150.255.1 255.255.255.252
interface vlan 160
description Site 2
ip address 10.160.255.1 255.255.255.252
Remote site routers:
[remote 1]
no ip address
speed 100
full-duplex
interface FastEthernet0/1.1
encapsulation dot1Q 150
ip address 10.150.255.2 255.255.255.252
encapsulation dot1Q 500 native
no ip address
speed 100
full-duplex
ip address 10.20.1.211 255.255.255.0
[remote 2]
no ip address
speed 100
full-duplex
encapsulation dot1Q 160
ip address 10.160.255.2 255.255.255.252
no ip address
speed 100
full-duplex
ip address 10.30.1.207 255.255.255.0
Brandon
07-17-2009 12:31 PM
You got it :)
07-17-2009 12:35 PM
Awesome,
And if I did go with the switch method at the HUB and say my remotes were 8MB ME connections to do QoS would at the hub end would I configure this under the VLAN sub-interfaces? I know a switch typically isn't as smart as a router (with QOS, shaping, etc...) so what would you advise for someone with these concerns.
Any recommendations?
Kind Regards,
Brandon
07-17-2009 12:42 PM
No shaping available on regular line cards on a 6500. You need a SIP with Ethernet SPAs. On the SPA, you would do shaping like a regular IOS router and apply the service-policy on the main interface.
HTH,
__
Edison.
