05-10-2007 11:41 PM - edited 03-05-2019 04:00 PM
Hi NetPro,
does ADSL cisco router 800 can block by Mac-Address ?
regards,
Jack
05-11-2007 12:07 AM
MAC address filtering support on 800 series depends on your router model.
Please post a show ver.
Bjornarsb
05-13-2007 06:31 PM
hi Bjornarsb,
thanks for reply, would it be possible only allow the specific user / Mac-address. can block the rest ?
currently, i am using DHCP pool with 6 IPs and i am using Host IP binding with Mac-address.
any good suggestion ?
regards,
Jackal
05-13-2007 10:40 PM
Yes that would be possible.
It depends on the 800 model and software.
To see for yourself a good idea is to use
feature navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH, rate if it does.
BR,
Bjornarsb
