Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
ADSL - Cisco 800 (urgent)
Hi NetPro,
does ADSL cisco router 800 can block by Mac-Address ?
regards,
Jack
Bronze
Re: ADSL - Cisco 800 (urgent)
MAC address filtering support on 800 series depends on your router model.
Please post a show ver.
Bjornarsb
hi Bjornarsb,
thanks for reply, would it be possible only allow the specific user / Mac-address. can block the rest ?
currently, i am using DHCP pool with 6 IPs and i am using Host IP binding with Mac-address.
any good suggestion ?
regards,
Jackal
Bronze
Yes that would be possible.
It depends on the 800 model and software.
To see for yourself a good idea is to use
feature navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH, rate if it does.
BR,
Bjornarsb
136
