ADSL on Fast Ethernet in 1801
I have cisco 1801W . Earlier I am using ADSL dynamic IP address  on RJ 11  through the ADSL Port but now the ISP change the connection to RJ45.
I am trying to configure it but unable to do this. ADSL line is okay because When I am connecting through the ISP router it is working fine. I have connected the ADSL RJ45 cable in the router fast ethernet 0.
But I wanted to use Cisco 1801 Router so that I can use the ADSL as primary and ISDN as the backup.
Below is my configuration please let me know eiteher this is possible to configure ADSL through RJ45 in 1801 and what configuratino require for this.
Router#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              unassigned      YES DHCP   up                    up
BRI0                       unassigned      YES unset  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
FastEthernet4              unassigned      YES unset  up                    down
FastEthernet5              unassigned      YES unset  up                    down
FastEthernet6              unassigned      YES unset  up                    down
FastEthernet7              unassigned      YES unset  up                    down
FastEthernet8              unassigned      YES unset  up                    down
Dot11Radio0                unassigned      YES unset  administratively down down
Dot11Radio1                unassigned      YES unset  administratively down down
ATM0                       unassigned      YES manual down                  down
Vlan1                      172.17.246.1    YES manual up                    down
Dialer1                    unassigned      NO  TFTP   up                    up
NVI0                       unassigned      NO  unset  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Router#
interface FastEthernet0
description ADSL
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio1
no ip address
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/50
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
interface Vlan1
ip address 172.17.246.1 255.255.255.0
ip nat inside
interface Dialer1
description ADSL
ip unnumbered FastEthernet0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 2
ppp pap sent-username eildxb12 password 0 rwxzenff
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer1 overload
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
control-plane
line con 0
line aux 0
line vty 0 4
Router#show interfaces atM  0
ATM0 is down, line protocol is down
  Hardware is MPC ATMSAR (with Alcatel ADSL Module)
  MTU 4470 bytes, sub MTU 4470, BW 4608 Kbit, DLY 80 usec,
  Encapsulation ATM, loopback not set
  Encapsulation(s): AAL5  AAL2, PVC mode
  23 maximum active VCs, 1024 VCs per VP, 0 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input never, output never, output hang never
  Queueing strategy: Per VC Queueing
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Please assist me how to configure this.
I am able to configure my ADSL connection successfully through the FastEthernet but now the backup ISDN is not working. I want to to use my ISDN line as backup in case when ADSL went down. I am confuse about the NAT configuration as well.
below is the configuration.
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 2
isdn switch-type basic-net3
ppp authentication chap callin
no ip address
shutdown
station-role root
no ip address
shutdown
48.0 54.0
station-role root
interface ATM0
no ip address
shutdown
pvc 0/50
interface Vlan1
ip nat inside
interface Dialer1
description ADSL
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username eildxb12 password 7
04491C1E152442480F
interface Dialer2
ip nat outside
encapsulation ppp
dialer pool 2
dialer idle-timeout 180
dialer string 400200044
dialer-group 2
no cdp enable
ppp pap sent-username eppcolub password 7
070A315C4D59481015
ip route 0.0.0.0 0.0.0.0 Dialer2 200
no ip http server
ip nat inside source list 102 interface Dialer2 overload
access-list 102 permit ip any any
dialer-list 2 protocol ip list 102
Re: ADSL on Fast Ethernet in 1801
Appreciate if anyone can help me out
512
