Advice on upgrade
Hi there,
I've been asked for recommendations on upgrading the switching infrstruature for a smallish company.
The have around 80 staff and I think the current infrastructure is overkill for the size of the company. The current kit is old and they have no GB ethernet ports. They currently have:-
Core Switch:
  • 1x Cisco c6509
with a 48 port fast ethernet module (WS-X6248-RJ-45)
and an 8 port fibre module (WS-X6408A-GBIC)
I'm looking to replace this with something with 72 ethernet ports and 8 fibre ports
Access Switches:
  • 2x 3500
Replacement needs at least 48 ports and 2 fibre modules each
  • and 2x 5500
Replacement needs at least 72 ports and 2 fibre modules each
I appreciate any advise on this as I am struggling! More than happy to provide more info as needed.
We may just replace the core switch depending on costs.
-Al
Silver
Advice on upgrade
If the access switches and 6509 are in the same room then how about buying two WS-X6848-TX-2T(total 96 ports) blades instead of new access switches and connect everything to 6509, Ofcourse the sup module and IOS has to support the blades.
Siddhartha
Hall of Fame Super Gold
Advice on upgrade
2x 3500
2x 5500
3500????  As in 3500XL and CatOS 5500????
Wow.  What kind of support do you have in mind?
I mean I would no longer touch these two models, period.
What are you trying to do?
Advice on upgrade
Yep thats them.
I'm looking to replace them with something new!
Cost is a factor though.
Cheers.
H
Advice on upgrade
If cost is a factor then consider Cisco Refurbish.
But I will never recommend 3500XL or CatOS 5500 to be deployed (even at home).
Advice on upgrade
Sorry but I may have been unclear.
I am looking to buy something to REPLACE these switches.
Maybe I shouldn't have used the word "upgrade" ;-)
Al
Advice on upgrade
NB - When replacing the core switch I'm looking for something that will work with the fiber uplinks and existing vlans.
Advice on upgrade
Ok.  To make it cheaper, I'd go for a router-on-a-stick.   What model of router will depend entirely on the WAN bandwidth.  Next, the switch.  I'd be looking at either a 2960 or a 2960S.  For ease of management, 2960S would be the best.  Whether or not you want GigabitEthernet-to-the-desktop is a moot point.  If you have a small WAN bandwidth then FastEthernet makes sense.
Super Bronze
Re: Advice on upgrade
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
For the low port densities you're describing, assuming all these devices are not at the same rack (if they were, then the suggestion to upgrade the line cards in the 6509 is worth considering), least expensive solution might be stackable switches, 3750-X for L3 and 3750-X or 2960S for L2.
Advice on upgrade
Great cheers. I assume I can get gbic modules for the 3750-x's for the uplinks?
Super Bronze
Disclaimer
Posting
GBIC no, SFP/SFP+ yes.  Choice of 4 SFP or (2 SFP and 2 SPF+)  modules.
PS:
Most newer stuff won't provide GBIC ports, although that doesn't mean you can not have GBIC on one side of a fiber link and SFP on the other.
SFP+ supports gig or 10 gig.
Thanks Joseph. I really appreciate your help with this.
I think I'm going to recommend 2x 3750s stacked to replace the "core" switch.
I'm not sure what SFPs to recommend however - do you know what's needed to connect to
WS-X6408A-GBIC fibre module?
Will I need a transceiver?
I have attached a picture if that helps :-)
Cheers,
Al
Super Bronze
Disclaimer
Posting
You'll likely want the SFP counterpart to your GBIC, e.g. SX to SX, LX/LH to LX/LH etc.
413
