Advice on which Cisco Switch to get ?
Dear All,
Have had a few issues with network lately and it was down to the ARP table size of our current HP V1910 switches. Looking to replace switches over time, but would like to standardise to Cisco switches if possible.
Please could you provide suggestion on a solid reliable Cisco switch which wont break the bank, that includes:
No ARP table size issue
PoE option
Managed
24 ports
Gigabit ports
Stackable
Thanks in advance
Silver
Hi, Cisco has a specific
Cisco has a specific Department that works with possible solutions for your network needs; you can contact our Pre-Sales and LAN Design Department at 800-553-6387 Opt. 1, then Opt. 1 or their direct phone number: 877-4695471.
They can advise you and provide you with the proper product information on pricing, positioning, features, and Compatibility. Support Monday through Friday, from 8:00 am to 8:00 pm EST.
Hope this helps.
Hi thanks for the quick
Hi thanks for the quick response, have you got a UK number ?
Here is the site were you can
Here is the site were you can get specific contact information for Cisco.
https://www.cisco.com/cisco/web/siteassets/contacts/index.html
OK Thanks guys
OK Thanks guys
Silver
Hi, This number 0800 404 7778
This number 0800 404 7778 should get you to the support team.
33
