Advice on which software to upgrade MWAM to
I have several MWAM blades housed in several C6000 chassis' currently running version 12.3(14)YX3. The most important feature we require is PDSN ver 3.  According to the feature navigator I should upgrade to 12.3(14)YX10 for the 6500 switch. I see there is a version 12.3(14)YX16 for the 7600 router. My question is, since the MWAM can operate on both the 6500 and 7600, whether I can load the YX16 software or whether I have to stick with YX10. Basically what I want to know; what is the most recent software I can run on the MWAM's on a 6500 that will support the PDSN ver 3 feature?  The Supervisor on 6509 NEB-A chassis is 720 MSFC 3 Version 12.2(18)SXF16, and the Supervisor on 6513 chassis is Sup 2 MSFC 2,
  • LAN Switching and Routing
Everyone's tags (1)
162
