age of switches
Morning, is there any way to tell the approximate age of a switch (mfg. date) ?
I can approximate by the datestamp on the IOS but was loking for a beter method ? Thanks, Bud.
  • LAN Switching and Routing
Re: age of switches
That's a tough one. I dont think there is any command which will tell you the mfg date of the switch.
-amit singh
Re: age of switches
Look at the chassis.
Re: age of switches
HI,
#show tech-support
Command will help you to see the entire Details of Switch.
Pls Rate if Helps ! !
Re: age of switches
hi, sh tech-supp does not show any production dates ! only the software release dates und the uptime is shown here... the only hint is as earliery noted look at the chassistop - the yellow laser class product note shows the manufactured date e.g Jul 16 2002
that is if it is still there----
good hunting..
Re: age of switches
I was hoping to find something that works remotely. I don't have the luxury of having someone at all of the sites. I can approximate the ages using model and IOS release dates. etc. but the bean-counters are looking for real answers. Thanks all for your help.
262
