Community Member
AIX 5.3/Cisco 6509 (IOS 12.2) and EtherChannel
I'm trying setup EtherChannel's between five AIX hosts (2 x 1GB ports) and a 6509. We are unable to get (and keep) our the etherchannels running.
Here's a section of our Switch configuration for one of the the EtherChannels:
interface Port-channel22
description LACP port channel for mcc510d, g2/45 and g3/45
switchport
switchport access vlan 1001
no ip address
interface GigabitEthernet2/45
switchport
mtu 9216
no ip address
channel-group 22 mode active
interface GigabitEthernet3/45
switchport
switchport mode access
mtu 9216
no ip address
interface Vlan1001
description Private VLAN mtu 9216
ip address 192.168.2.1 255.255.254.0
On AIX we are setting it as 802.3ad
Any help would be greatly appreciated!
-Kevin Burke
Community Member
Re: AIX 5.3/Cisco 6509 (IOS 12.2) and EtherChannel
You have not specified the channel- protocol in the ports which contibutes to the port-channel
eg:-
hostname(config-if)channel-protocol lacp
Community Member
What's odd, is when I connect just the first 1GB adapter I get an aggregated connection. It only when I try to add the second 1GB adapter that things don't work.
I'll give your suggestion a try.
-Kevin
Community Member
I'm having similar issue as Kevin.
And
will set the protocol to LACP.
The channel-protocol line is implied.
However my issue is that I do get the AIX server and 6513 switch to etherchannel, until the VIOS (in the AIX server) reboots.
Then I have to shutdown and no shutdown the Portchannel, in order to reactivate the connection; (connection is broken and not non-channeled).
Anyone got this same issue and found a fix?
876
