03-06-2007 03:15 AM - edited 03-05-2019 02:43 PM
I have 28 x 3550 xl's and the cpu times and response time are 50% higher than all the 3550 smi i have. Has anyone else noticed a performance issue with 3550xl's. I plan to replace them. What is the recommend replacements for 3550xl's
03-06-2007 03:20 AM
You can use 3560's ...
First I would try to check if the IOS images are not old or buggy before replacing them
That could be your problem.
If you find this post usefull
please don't forget to rate this
#Iwan Hoogendoorn
03-06-2007 03:24 AM
I will need to connect 3 switches together via gigabit modules can this be performed with the 3560
03-06-2007 03:27 AM
Yes this can be sone ... the 3560's all have gigabit interfaces and if you want to use fiber you need to use the GBIC'S
#Iwan Hoogendoorn
03-06-2007 04:32 AM
So are you sayng the 3560 are gigastack able like 3550
