Allow traffic between interfaces
itsupport
I have spent the last few hours reading different documents but I am still coming up empty handed.
I've got a ASA 5525, has a inside interface & sits at 10.33.1.1
I defined a logical interfaces with vlan tag 3364 -- sits at 10.33.64.1 (this will be for our wifi clients)
Both have security set to 100.
I set:
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
However a client at 10.33.1.5 cannot ping 10.33.64.1 & vica versa.
I've tried access rules, NAT rules & messing with PAT settings but not sure what I'm missing.
I attached a sanitized config & removed stuff around our VPN tunnel & other authentication. Any help would be much appreciated
8 Replies 8
Reza Sharifi
Don't add IP to the main interface. Try both vlans using sub-interfaces
try this:
interface GigabitEthernet0/2
description Inside interface
nameif inside
no sh
interface GigabitEthernet0/2.100
vlan 100
nameif vlan100
security-level 100
ip address 10.33.64.1 255.255.255.0
interface GigabitEthernet0/2.200
vlan 200
nameif vlan200
security-level 100
ip address 10.33.1.1 255.255.255.0
and try pinging from one to the other.
I did the following to make sure I don't accidently lock myself out...
nameif inside
security-level 100
vlan 100
nameif vlan100
security-level 100
vlan 200
nameif vlan200
security-level 100
ip address 10.33.2.1 255.255.255.0
packet-tracer input vlan100 icmp 10.33.64.1 8 5 5 10.33.2.1 xml
drop
(no-route) No route to host
We never had any vlans defined beforehand on this firewall -- if I'm adding them now does it require that I now specify a vlan on every interface?
It would just be helpful to still be able to use the native vlan because the switches underneath this ASA don't have switchport access vlan configured on any of their ports.
nameif inside (not recomended for sub interfaces)
security-level 100 (not recomended for sub interfaces)
ip address 10.33.1.1 255.255.255.0   (not recomended for sub interfaces)
vlan 100
nameif vlan100
security-level 100
vlan 200
nameif vlan200
security-level 100
Also check
FW GigabitEthernet0/2 connected to switch must be in trunk allowed vlan 200, 100
Jawad
Jawad
Is there anyway to make one of the sub interfaces use the native vlan? I tried setting Vlan to 1 but it didn't work.
on the ASA the native VLAN is taken care of on the main physical interface.
Alain
Put the following command in router under the sub-interface you want to use native vlan.
#encapsulation dot1Q 1 native
On the switch, if you have a native VLAN other than VLAN1,configure the same
VLAN on the router to be the native VLAN,by using the above command.
I was able to get this working the way I needed it to
nameif inside
security-level 100
interface GigabitEthernet0/2.64
vlan 64
nameif WiFi
security-level 100
nat (inside,any) source static obj-10.33.1.0 obj-10.33.1.0 destination static obj-10.33.64.0 obj-10.33.64.0 no-proxy-arp
Thanks for the help
