Allow VPN connection from inside network.
Can anyone help in configuring a VPN connection from inside network to another network through VPN.
i need to allow a host on my inside network to access a server of one company.its hosted on public IP.
eg.10.0.0.1 should be able to access 212.X.X.10.
Mahmood
Re: Allow VPN connection from inside network.
What kinda security equipments you are using out there ?
Are you using a router to create the vpn tunnel or a PIX/ASA ?
regds
Thanks for the reply.currently we are using PIX.
Mahmood
124
