Alot of traffic on a blocked Spanning Tree port
Hi to all!
I have two WS-C4507R (Version 12.2(25)EWA9) connected in redundancy using HSRP and i've noticed that in the ports that are blocked by spanning tree on the secondary switch are having alot of traffic, for example there are moments that a blocked interface has more than 65Mbps of traffic volume. I understand that in blocked ports there is some BPDU traffic but I don't believe it's going to be this amount. Here are some outputs of the switch:
VLAN0601
Spanning tree enabled protocol ieee
Root ID Priority 4697
Address 001b.54bd.c9c0
Cost 4
Port 129 (GigabitEthernet3/1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 4697 (priority 4096 sys-id-ext 601)
Address 001b.d473.95c0
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Te1/1 Desg FWD 2 128.1 P2p
Gi3/1 Root FWD 4 128.129 P2p
Gi3/3 Desg FWD 4 128.131 P2p
Gi3/5 Desg FWD 4 128.133 P2p
Gi3/6 Desg FWD 4 128.134 P2p
Gi5/1 Desg FWD 4 128.257 P2p
Gi5/2 Desg FWD 4 128.258 P2p
Gi5/3 Desg FWD 4 128.259 P2p
Gi5/4 Desg FWD 4 128.260 P2p
Gi5/5 Desg FWD 4 128.261 P2p
Gi5/6 Desg FWD 4 128.262 P2p
Gi7/18 Desg FWD 4 128.402 P2p
Gi7/41 Altn BLK 4 128.425 P2p
Gi7/45 Desg FWD 4 128.429 P2p
Gi7/46 Desg FWD 4 128.430 P2p
GigabitEthernet7/41 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 001b.d4b6.2a58 (bia 001b.d4b6.2a58)
Description: TO-DB-SWITCH1
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is on, output flow-control is on
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 24w3d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 80000 bits/sec, 70 packets/sec
1371903409 packets input, 298989812674 bytes, 0 no buffer
Received 1214261962 broadcasts (821127917 multicast)
7007883 packets output, 634785274 bytes, 0 underruns
0 lost carrier, 0 no carrier
I'll appreciate your help...
Thanks in advance...
Re: Alot of traffic on a blocked Spanning Tree port
This most likely a broadcast traffic. If you notice the traffic is just "input" not "output". My suggestion is to "sniff" that port and find out what kind of traffic is going thru.
Hall of Fame Super Silver
you are right see:
88% of received frames are broadcast or multicast sent out by the designated port
Best Regards
Giuseppe
Hi to all!
Yes i noticed that...
Thanks for your help...
can you paste the show processes cpu on your secondary switch?
163
