Alternate method to Xmodem
carbonscoring
Hi All, I have a switch that a co-worker, while trying to upgrade the IOS, in the process deleted the existing IOS without successfully uploading the new IOS. Anyway I'm at the point of upgrading through Xmodem but, I have to imagine there is a quicker method.
Here are the details on the switch
Cisco 3750-48T
Any suggestions?
thanks,
Mike
Also, if your 3750 and terminal simulator supports something better than Xmodem, use the better protocol. (Even Xmodem-1K.)
PS:
Unsure, but some hosts and Cisco devices might support even faster than 115K, if they do, use it.
Also, if you can, you might want to reset BAUD rate before actual reload. Otherwise, it might become the new default speed, which makes it difficult to get on the device at 9600 next time you need to.
5 Replies 5
Leo Laohoo
Other than X-Modem at 9600? Try changing the baud settings to 115K.
As above said:
set BAUD 115200
disconnect the session and reconnect with the correct BAUD setting
PS:
Thanks guys for your help, I wasen't able to TFTP I looked it up and you can only use this for Routers. I forgot about what Joseph said about reseting the Baud rate before reloading. Wasent a big issue I just had to reboot back into ROMMON mode and set the Baud rate from there.
thanks,
Mike
tmsundar81
Mike
The other fastest way is to use tftpdnld command, the config example is available on the following link..
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
May be you can give it a try..
Sundar.
