Another OSPF tunneling question
hugh2_nguyen
Hello all,
Thanks for all the advices on how to set up tunneling for ospf. In my test network, I used a switch to simulate a WAN sitting in between the two routers. I can ping every node on ospf networks without setting up static route in the routers and I guess that because the tunneling IP addresses are in the same subnet and they both connected to the switch. Should I connect to a WAN that I have no administrative privilege over, do I need to set up static route in the routers so that they would know which WAN gateways to use (i.e. 192.x.x.152 and 142.x.x.152 are interfaces of the WAN entry points for routers 4 and 5 respectively)? What should the ip routes be? Here're current config files:
hostname Router4
policy-map FQ
class class-default
fair-queue
interface Tunnel0
ip address 10.1.1.1 255.255.255.0
tunnel source GigabitEthernet0/0
tunnel destination 142.x.x.105
interface GigabitEthernet0/0
Description external WAN
ip address 192.x.x.104 255.255.255.0
duplex auto
speed auto
ipv6 enable
ospfv3 instance 64 network manet
ospfv3 1 area 0 address-family ipv4 instance 64
service-policy output FQ
interface GigabitEthernet0/1
Description internal LAN
ip address 192.x.2.40 255.255.255.0
duplex auto
speed auto
ipv6 enable
router ospfv3 1
router-id 4.4.4.4
log-adjacency-changes
address-family ipv4
timers spf 1 2
router-id 4.4.4.4
exit-address-family
ip forward-protocol nd
hostname Router5
policy-map FQ
class class-default
fair-queue
interface Tunnel0
ip address 10.1.1.2 255.255.255.0
ip address 142.x.x.105 255.255.255.0
duplex auto
speed auto
ipv6 enable
ip address 192.x.4.40 255.255.255.0
duplex auto
speed auto
ipv6 enable
router ospfv3 1
router-id 5.5.5.5
address-family ipv4
timers spf 1 2
router-id 5.5.5.5
exit-address-family
Thanks.
yagnesh_tel
Hi Hugh,
One of the requirement for building GRE is that the tunnel destination address must be reachable from the interface other than tunnel itself. This is because if the tunnel destination is reached through the tunnel then there will be recursive routing and the tunnel will be brought down with error.
So you will require to specify how you will reach tunnel destination on both routers using static routes pointing towards WAN gateways.
For example on Router 4
ip route 142.x.x.105 255.255.255.255
Also be sure to not advertise these tunnel ends from other end using OSPF.
Thanks!
