Webcast-Catalyst9k
Any copper<->fiber media converter for 2950 and 3750 switches?
Folks, just want to confirm:
On siteA I have a fiber connection to SONET. I have one Cisco Cat 2950 FastEthernet switch 24 Port.
Is it possible to buy media converter to let me connect one FastE port to the fiber SONET switchport? If so, which model is that?
On SiteB I have 3750 24P switch. Same situation, I would need a media converter copper port->Fiber.
I recall I used a converter in the past for the 3750 and that worked but I am not sure if model is the same for the 2950.
This is a temporary solution since in the future 2950 switches should be replaced by 3750 with gbics on both SiteA and SiteB.
1 ACCEPTED SOLUTION
Re: Any copper<->fiber media converter for 2950 and 3750 swit
Hall of Fame Super Bronze
You can't terminate a SONET connection into an Ethernet port.
For SONET termination, you need a 7200 VXR with a SONET Port Adapter.
Similar situation, you can't terminate a T1 on a regular Cisco switch? T1 connection is copper and the port accept copper connection. Do you understand why it wouldn't work?
__
Edison.
Oh, sorry for my misexplanation.
In this case the SONET is terminated already, so I will have a LC, MM connector available for me to connect my 2950 to.
Hall of Fame Super Gold
What is the exact model of your 2950?
WS-C2960G-24TC-L
I thought you said you have a 2950?
Anyways ... 2960G has four (4) dual-personality ports (Copper or SFP). Just get the corresponding SFP.
1166
