Any ideas why this host does not work on some switchports?
Imagine I have a 2950 switch. Switch is connected via port fa0/48 to 3750 Layer 3.
On 2950switch, switchportports fa0/10, switchport access vlan 100. A host is connected to that port and I can ping it OK.
Then technician attemtpts to connect same functional host to ports fa0/11 or fa0/12 or fa0/13 on 2950switch and then host does not communicate (ping times out) when it is connected to any of those ports. Such switchports are configured with identical VLANs settings, duplex, etc.
Any ideas on what could be wrong here? I thought that it could be unlikely all three ports fa0/11-fa0/13 went bad on that 2950switch...
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: Any ideas why this host does not work on some switchports?
I see egress traffic but no ingress traffic. I suspect a bad cable. Are you using the same cable while moving from one switchport to another?
Is the device connecting directly to the switch or going via some kind of patch panel?
Try:
(config)#default interface f0/11
(config)#interface f0/11
(config)#switchport mode access
(config)#switchport access vlan 100
__
Edison.
Silver
Any other know working hosts work on those ports?
Connected another host;same behavior. It works on port fa0/10 and it does not work on port fa0/11.
What's the status of the interface?
up/up?
Check for err-disabled status.
__
Edison.
Here is the actual output from the bad port. The only wrong info I noticed is the "2 input errors, 2 CRC". Yes, it is up/up.
Notice I inherited 'bpdufilter' config and I know that should be removed, but I do not believe that is causing the problem.
2950#show int fa0/11
FastEthernet0/11 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0027.e07d.ac59 (bia 0027.e03d.ax59)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 100BaseTX
input flow-control is unsupported output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 1000 bits/sec, 2 packets/sec
0 packets input, 331 bytes, 0 no buffer
Received 0 broadcasts (0 multicast)
2 input errors, 2 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
41654 packets output, 2862803 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
interface FastEthernet0/10
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
end
2950#show run int f0/11
Building configuration...
Current configuration : 149 bytes
interface FastEthernet0/11
end
Try:
__
Edison.
Same cable and host that worked on port fa0/10 was connected directly to port fa0/11 and then it did not work.
Let me try input the config on the switchport and see. I am aware that I inherited the lack of switchport mode access as well and that should be included, although 'mode access' should not cause issues related to this problem.
can you provide copy of the config from port fa0/10 to fa0/14 ? this may help us to understand a bit more.
thanks
Shaheen
Hall of Fame Super Gold
Edison's right. Traffic is only one way. Can you plug the ping-able host to Fa 0/11 using the other cable and compare the result?
I did that and cable which worked on fa0/10 device is same cable on device on fa0/11; problem persists.
Also, tech onsite tells me a couple of ports fa0/20 and fa0/24 (which does not work either) is showing amber LED on - and there is nothing connected to ports at all. It really seems we have a faulty hardware unless you can think of something else to do.
Faulty hardware indeed, no need to waste cycles on this, call your Cisco sales and get a replacement :)
you can use cross over cable to plug directly between 2 ports to test if the port is faulty.
147
