Any way to recover / reset VTP password
Hi Guys,
I was just wondering that is there any way to recover / reset forgotten VTP password (other than reseting the box itself) like what we do to reset password on router (CRTL+BREAL sequence and then changing config register).
I tried googling around, but didn't find any useful info though.
Maybe, CSC experts can help :-)
Smitesh
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Re: Any way to recover / reset VTP password
Did u try show vtp password..?
if not then u can see the vtp password in the vlan.dat file.
u can use the command from enable mode.
switch#more vlan.dat
the first line will show u the password.
As other friends here have already indicated, you can try to use the show vtp password command in the privileged mode. If you are running the VTPv1 or VTPv2, this command will show you the password in cleartext form. With VTPv3, the password may be stored in an encrypted form and you will not be able to find out its original cleartext form.
In any case, you can always change the VTP password using the global configuration commands
no vtp password ! Removes the VTP password
vtp password NewS3cretP4s5w0rd ! Configures a new password
Best regards,
Peter
Isn't VTP password encrypted ?
Its encypted but i  have seen many times it appear in the vlan.dat file.
Have u tried more vlan.dat command..?
Hi Mahmood,
As of now i don't have access to switch.
Also, it is not an problem which i'm facing, but a general query; which just popped of from somewhere.
So, i was just trying to find the way.
Smitesh
Best regards,
Peter
3448
