Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Are the blades hot-swappable?
I have a 4510R switch. i need to upgrade the 100mb ethernet blades to 1gb, can i do this while the unit is on ?.
thanks
rob davis
Everyone's tags (1)
Re: Are the blades hot-swappable?
All Catalyst 4500 series switches support hot swapping, which lets you install, remove, replace, and rearrange switching modules without turning off the system power. When the system detects that a switching module has been installed or removed, it runs diagnostic and discovery tests automatically, acknowledges the presence or absence of the module, and resumes system operation with no operator intervention.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/configuration/notes/gMdCf_nt.html
HTH,
Lei Tian
VIP Super Bronze
Hi Rob,
Even through they are hot swappable, I recommend doing this during an outage window, because you never know what can go wrong.
Reza
433
