Are the following Switches supporting SM or MM fiber Patch Cords cables
gentelemen,
we recived the following switches.
WS-C4507R-ECat4500 E-Series 7-Slot Chassis, fan, no ps, Red Sup Capable
WS-C2960S-24TS-SCatalyst 2960S 24 GigE, 2 x SFP LAN Lite
WS-C3750X-24T-SCatalyst 3750X 24 Port Data IP Base
GLC-LH-SMGE SFP, LC connector LX/LH transceiver
The current situation that all existing Fiber Patch Cords cables & fiber cables coming from field are multimode. So, I think we have a compatibility issues. We need clarifications from your, what are the options that we can do to resolve this issue.
  • Can we connect the above switches to multimode Fiber Patch Cords cables?
Thanks alot Maidu,
Please can you be more specific. I am not an expert in Cisco products.
How I be sure that switches with above specificatiosn are supporting MM fiber patch cables.
Hi hani,
I am sure that they support because I have used those 2960 and 3750 for one of my customer and we used MMF (multimode fiber) only.
The 1G or 10G SFP slots you have on the switches, so you need to have the exact SFP modules to support multimode fiber.
We used the following modules..
Uplinks 10G Modules: SFP-10GB-SR/LRM
Switch interconnecting modules: SFP-H10GB-CU3M
1G SFP fiber Module: GLC-SX-MM
Please rate all the helpfull posts.
Naidu.
Re: Are the following Switches supporting SM or MM fiber Patch C
Naidu,
first of all, i rate the below wrongly,
How i can know each SFP in each switch supports MM.
for WS-C4507R-E, we have:
WS-X4624-SFP-ECatalyst 4500 E-Series 24-Port GE (SFP)
WS-X45-SUP6-ECatalyst 4500 E-Series Sup 6-E, 2x10GE(X2) w/ Twin Gig
WS-X45-SUP6-E/2Catalyst 45xxR E-Series Sup 6-E, 2x10GE(X2) w/ Twin Gig
WS-X4248-RJ45VCatalyst 4500 PoE 802.3af 10/100, 48-Ports (RJ45)
S45EIPBK9-12253SGCisco CAT4500E IOS IP BASE SSH
PWR-C45-2800ACVCatalyst 4500 2800W AC Power Supply (Data and PoE)
PWR-C45-2800ACV/2Catalyst 4500 2800W AC Power Supply (Data and PoE)
CAB-AC-2800W-TWLKU.S. Power Cord, Twist Lock, NEMA 6-20 Plug
CVR-X2-SFPCisco TwinGig Converter Module
for WS-C2960S-24TS-S, we have:
GLC-LH-SM=GE SFP, LC connector LX/LH transceiver
CAB-16AWG-ACAC Power cord, 16AWG
for WS-C3750X-24T-S, we have:
C3KX-PWR-350WACCatalyst 3K-X 350W AC Power Supply
C3KX-NM-1GCatalyst 3K-X 1G Network Module option PID
C3KX-PWR-350WAC/2Catalyst 3K-X 350W AC Secondary Power Supply
CAB-3KX-ACAC Power Cord for Catalyst 3K-X (North America)
CAB-CONSOLE-USBConsole Cable 6 ft with USB Type A and mini-B
CAB-SPWR-30CMCatalyst 3750X Stack Power Cable 30 CM
CAB-STACK-50CMCisco StackWise 50CM Stacking Cable
S375XVK9T-12255SECAT 3750X IOS UNIVERSAL WITH WEB BASE DEV MGR
494
