Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ARP and MAC Limit
What is the ios behaviour if for eg 7600 or 6500 exceed the sup or interface arp/mac limit.Will it drop the new arp request or overide the oldest?Any document for the same?
1 REPLY
Re: ARP and MAC Limit
I read your posting and I looked for more info on Cisco.com, I found a document with indepth arp information and commands. I would think thst if the mac-address arp table was full and unable to forward any additional layer 2 frames, then the new entry would not be established and entered into the table, until an existing entry timed out. There is a command you can use to setup a loggin alert when the arp table reaches a certain limit. HTH
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_arp.html
188
